Transform menu: Scale tool
Learn how to resize 3D geometry proportionally or along individual axes using the Scale tool.
What is the Scale tool?
You can use the Scale icon-transform-scale.png tool to resize 3D geometry uniformly or non-uniformly around a chosen center point. Uniform scaling preserves proportions, while non-uniform scaling adjusts the size independently along the X, Y, and Z axes.
To resize sketch items, use the Sketch menu: Scale tool.
How to use the Scale tool
  1. Go to Transform > Scale.
  2. Select the geometry you want to scale.
  3. Choose a scaling Type:
    • Uniform – Scale the selection proportionally in all directions.
    • Non-Uniform – Scale the selection independently along the X, Y, and Z axes.
  4. If needed, reposition the gizmo center icon-gizmo-center.png to set the center point for scaling.
  5. Optional: To scale a copy while keeping the original, turn on Copy icon-generic-copy-false.png. The Copy badge icon-generic-copy-true.png appears blue when selected.
  6. Use the gizmo or enter scale values to resize the selection.
  7. Optional: To adjust settings while the tool is active, select Scale again to open the parameter card.
  8. To finish, select an empty area of the modeling space.
Adjust Scale parameters
While using Scale, select Scale again to open its parameter card and adjust the following:
  • To Scale – Select or change the geometry to scale.
  • Type – Choose Uniform to scale proportionally or Non-Uniform to scale independently along the X, Y, and Z axes.
  • Scale – When using Uniform, enter a single scale factor for all axes.
  • Scale X, Scale Y, Scale Z – When using Non-Uniform, enter separate scale factors for each axis.
  • Copy – Turn on to create a scaled copy while keeping the original geometry unchanged.
Edit Scale in History
To adjust a completed Scale operation:
  1. Open the History sidebar.
  2. Select the Scale step to reopen its parameter card.
  3. Adjust To Scale, Type, the available scale values, or Copy as needed.
  4. To finish editing, click anywhere in an empty area of the modeling space.
When to use the Scale tool
The Scale tool is useful for:
  • Resizing models – Enlarge or reduce an existing body to fit a design requirement.
  • Adjusting proportions – Stretch or compress geometry along individual axes.
  • Creating size variations – Make scaled copies of a model while retaining the original.
  • Scaling around a reference point – Control how geometry expands or contracts relative to a chosen center.
  • Use Uniform scaling when you need to preserve the original proportions.
  • Reposition the gizmo center before scaling when you want to keep a specific location fixed.
  • Use precise scale factors when you need repeatable results.
Issue What to check
The model changes proportions unexpectedly. Check whether Type is set to Non-Uniform. Use Uniform to preserve proportions.
The model scales from the wrong point. Reposition the gizmo center before adjusting the scale.
The original geometry changes when a duplicate was intended. Turn on Copy before scaling.
5 out of 19 found this helpful
