Learn how to rotate 3D geometry around a selected axis in Shapr3D.
What is the Rotate Around Axis tool?
You can use the Rotate Around Axis tool to rotate bodies, faces, edges, and sketch profiles around a selected axis. Enter a precise angle or use the rotation control, and optionally create a rotated copy of the selection.
To learn how to rotate sketch items, visit Sketch menu: Rotate Around Axis tool.
How to use the Rotate Around Axis tool
- Go to Transform > Rotate Around Axis.
For other ways to access tools, visit Accessing tools. - Select the bodies, faces, edges, or sketch profiles you want to rotate.
- Select Next, if prompted, to proceed to axis selection.
- Select the axis, line, or edge to rotate around.
- Optional: Select the Copy badge to rotate a duplicate instead of the original selection.
- Drag the rotation control or select the angle label to specify the rotation angle.
- Optional: To adjust settings while the tool is active, select Rotate Around Axis again to open the parameter card.
- Select Done to finish.
Turn on Copy to create a rotated duplicate while keeping the original selection unchanged.
Adjust Rotate Around Axis parameters
While using Rotate Around Axis, select Rotate Around Axis again to open its parameter card and adjust the following:
- To Rotate – Select or change the geometry to rotate.
- Axis – Select or change the line, edge, or axis used as the rotation reference.
- Angle – Specify the rotation angle.
- Copy – Turn on to create a rotated copy while keeping the original selection unchanged.
Edit Rotate Around Axis in History
To adjust a completed Rotate Around Axis operation:
- Open the History sidebar.
- Select the Rotate Around Axis step to reopen its parameter card.
- Adjust the parameters as needed.
- To finish editing, click anywhere in an empty area of the modeling space.
When to use the Rotate Around Axis tool
Use Rotate Around Axis to:
- Position angled components – Rotate parts around a hinge, shaft, or other reference axis.
- Create rotational variants – Duplicate and rotate geometry to compare or arrange alternatives.
- Adjust 3D features – Rotate selected faces or bodies by an exact angle.
- Choose a stable reference axis before entering the rotation angle.
- Use the parameter card or the dedicated History step when you need to revise the operation.
| Issue | What to check |
| The geometry rotates around the wrong location. | Check the selected Axis in the parameter card. |
| The original geometry was rotated instead of copied. | Turn on Copy before completing the operation. |
| The rotation needs to be changed after completion. | Open the Rotate Around Axis History step and adjust the parameters. |
