Learn how to use Mirror to create symmetrical 3D geometry.
What is the Mirror tool?
You can use the Mirror tool to mirror bodies or faces across a selected plane to create symmetrical 3D geometry.
To mirror sketch items, use the Mirror tool in the Sketch menu.
How to use the Mirror tool
To mirror 3D geometry:
- Go to Transform > Mirror.
For other ways to access tools, visit Accessing tools. - Select the bodies or faces you want to mirror. Selected geometry is highlighted and marked with a selection badge.
- Select a plane, planar face, or other supported reference to define the Mirror Plane. The selected mirror reference is highlighted in purple.
- Optional: Turn off Keep Original to remove the original geometry after mirroring.
- Optional: To adjust settings while the tool is active, select Mirror again to open the parameter card.
- To finish, select Done.
Adjust Mirror parameters
While using Mirror, select Mirror again to open its parameter card and adjust the following:
- To Mirror – Select or change the geometry to mirror.
- Mirror Plane – Select or change the plane or reference used to mirror the geometry.
- Keep Original – Turn on to retain the original geometry alongside the mirrored result. Turn off to keep only the mirrored result.
Edit Mirror in History
To adjust a completed Mirror operation:
- Open the History sidebar.
- Select the Mirror step to reopen its parameter card.
- Adjust the parameters as needed.
- To finish editing, click anywhere in an empty area of the modeling space.
When to use the Mirror tool
The Mirror tool is useful for creating:
- Symmetrical parts – Create mirrored bodies for balanced components or assemblies.
- Matching features – Reflect faces or geometry to the opposite side of a model.
- Alternative layouts – Create a mirrored version while retaining the original when needed.
- Select the geometry you want to mirror before choosing the mirror reference.
- Use a clearly defined centerline or plane to position the mirrored geometry accurately.
- Review the preview before finishing the operation.
| Issue | What to check |
| The mirrored body is in the wrong location. | Check the selected Mirror Plane. |
| The original body is missing. | Check whether Keep Original is turned on. |
| Unexpected geometry is mirrored. | Review the To Mirror selection in the parameter card. |
