Screenshot tool: Capture images of your model
Learn how to capture images of your model, customize screenshot appearance and resolution, and save or copy images directly from the Screenshot tool.
What is the Screenshot tool?
You can use the Screenshot tool icon-screenshot.png to capture clean images of your model without interface elements. The Screenshot tool is available in both the modeling space and Visualization.
The Screenshot tool opens a dedicated dialog where you can preview your model, customize its appearance, adjust the output resolution, and save or copy the resulting image. You can also access Generative Render to create AI-enhanced images of your model.
Use the Screenshot tool to:
  • Capture clean images of your model without interface elements.
  • Customize the appearance and resolution of your images.
  • Save or copy images for documentation, presentations, or design feedback.
  • Generate AI-enhanced renders of your model.
How to take a screenshot
  1. Open your project.
  2. In the modeling space, adjust the view and visibility of your model to prepare it for capture.
  3. Select Screenshot icon-screenshot.png to open the Screenshot dialog.
  4. Use the toolbar at the top of the dialog to customize the screenshot settings. The preview displays how your captured image will appear.
  5. Choose how you want to use the image:
    • Copy: Copy the image to your clipboard to paste it into another application.
    • Save: Save the image as a file on your device.
  6. To close the Screenshot dialog, select Done.
Screenshot settings
Use the toolbar at the top of the Screenshot dialog to customize the appearance and resolution of your image before saving or copying it.
Appearance
  • View Mode – Choose how your model is displayed in the captured image.
  • Grid screenshot-grid.png – Show or hide the grid in the background.
  • Transparency icon-view-transparent.png – Choose between a transparent or filled background.
  • Body Edges icon-view-bodyedge.png – Show or hide the edges of your model.
Tip: Before opening the Screenshot dialog, use the Items Manager to control which items are visible in your model.
Resolution
Use the Resolution dropdown to select the output size of your screenshot:
Resolution Description
Actual Captures the image at the current size of your workspace window.
Double Captures the image at twice the current resolution for improved clarity.
Full HD Captures the image at 1920 × 1080 pixels.
4K Captures the image at 3840 × 2160 pixels.
8K Captures the image at 7680 × 4320 pixels.
The output dimensions of the image are displayed below the preview. Higher resolutions provide more image detail but may result in larger file sizes.
Copy and reuse your last screenshot setup
The Screenshot tool lets you quickly reuse your previous screenshot settings and share captured images:
  • Remembered settings: The tool remembers your last used settings, including grid, transparency, and body edge visibility.
  • Automatic setup: Your previous settings are automatically applied when you reopen the Screenshot dialog.
  • Quick copy: Use a keyboard shortcut to copy your last screenshot without reopening the tool.
  • Clipboard access: Paste your copied screenshot directly into emails, presentations, documents, or other applications.
Generate AI renders
You can access Generative Render directly from the Screenshot dialog to create AI-enhanced images of your model.
Use a text prompt to describe how you want your model to appear, such as placing it in a realistic environment or exploring different visual styles.
To learn how to generate and save AI-enhanced images, visit Generative Render: Generate AI renders of your model.
105 out of 119 found this helpful
