Generative Render: Generate AI renders of your model
Learn how to use Generative Render in Shapr3D to create AI-enhanced images of your model using text prompts.
Feature availability by plan
Generative AI rendering is available with select Shapr3D plans. Usage limits and access to features vary depending on your subscription.
For details on available plans and their limits, visit our Pricing page.
Note: Generative AI rendering is not included with Educational licenses.
What is Generative Render?
You can use Generative Render to create AI-enhanced images of your model using text prompts. Describe how you want your captured model to appear, then generate and save the resulting image.
Generative Render is accessible from the Screenshot dialog in both the modeling space and Visualization.
Use Generative Render to:
  • Present your model in a realistic environment or use-case scenario.
  • Explore different visual styles and lighting conditions.
  • Create contextual images for design presentations and concept reviews.
  • Communicate design ideas without manually creating a detailed scene.
Note: Generative Render has a daily usage limit.
How to generate AI renders
  1. Open your project.
  2. In the modeling space or Visualization, adjust the view and appearance of your model to prepare it for rendering.
  3. Select Screenshot icon-screenshot.png to open the Screenshot dialog.
  4. Optional: Customize the appearance of your model using the screenshot settings.
  5. At the top of the Screenshot dialog, select Generative Render.
    Note: If Sync is disabled, you'll be prompted to enable Sync before continuing.
  6. Enter a prompt describing how you want the generated image to appear.
  7. Select Generate.
  8. Select Save Image to save the generated image.
Example of an AI-generated render in Shapr3D
Tips for writing prompts
A clear and descriptive prompt helps Generative Render produce an image that better reflects your intended result.
When writing a prompt, consider describing:
  • Environment: Where the model should appear, such as a studio, living room, workshop, or outdoor setting.
  • Lighting: The desired lighting conditions, such as natural daylight, soft studio lighting, or dramatic shadows.
  • Visual style: The intended appearance of the image, such as realistic product photography or a conceptual presentation.
  • Context: How the model should be presented or used within the scene.
Example prompts:
  • Show this car dashboard in context. Through the windshield, show a pine forest in the Rocky Mountains.
  • Place this product on a wooden desk in a modern home office with soft natural daylight.
  • Present this model against a neutral studio background with soft lighting and realistic shadows.
Note: AI-generated images may differ from the original model in appearance or geometric detail. Review the generated result before using it in design presentations or other materials.
To learn how to capture and customize images of your model, visit Screenshot tool: Capture images of your model.
To learn how to apply materials and customize the appearance of your model, visit Visualization.
For details on how this feature uses AI and processes your data, visit Generative Render In-App User Guide and Data Use Overview.
Commitment to transparency
Shapr3D’s AI features are developed with a focus on transparency, data security, and user trust. We ensure that all AI interactions comply with strict privacy and safety standards, and that your data is handled responsibly.
To learn more about how Shapr3D designs and governs AI systems, visit Our AI Approach.
You can also review our Terms and Conditions for information and terms on use of the app, and our Privacy Policy for detailed information about how we protect and process your data.
For a complete list of Shapr3D’s AI partners, visit our Subprocessors and AI service providers list.
475 out of 563 found this helpful
