Learn how to resize sketch items proportionally or along individual axes using the Scale tool.
What is the Scale tool?
You can use the Scale tool to resize sketch items uniformly or non-uniformly around a chosen center point. Uniform scaling preserves proportions, while non-uniform scaling lets you adjust dimensions independently.
To learn how to scale 3D geometry, visit Transform menu: Scale tool.
How to use the Scale tool
- Go to Sketch > Scale.
For other ways to access tools, visit Accessing tools. - Select the sketch items you want to scale.
- Choose a scaling Type:
- Uniform – Resize the selection proportionally in all directions.
- Non-Uniform – Resize the selection independently along the available axes.
- If needed, reposition the gizmo center
to set the center point for scaling.
Optional: To scale a copy while keeping the original, turn on Copy
. The Copy badge
appears blue when selected.
- Use the gizmo or its dimension labels to adjust the scale.
- Optional: To adjust settings while the tool is active, select Scale again to open the parameter card.
- To finish, select an empty area of the modeling space.
The Scale tool includes a parameter card for adjusting settings while the tool is active. Scaling sketch items does not create a separate Scale step in History. Instead, the changes are reflected in the existing Sketch step.
Adjust Scale parameters
While using Scale, select Scale again to open its parameter card and adjust the following:
- Type – Choose Uniform to scale proportionally or Non-Uniform to scale along individual axes.
Scaling sketch items does not create a separate Scale step in History. You can still reopen the existing Sketch step to review or modify its settings:
- Plane – Select Edit… or Select… to change the plane or face containing the sketch, then select Done.
- Projection – If applicable, select Edit… to modify existing projections in the sketch.
When to use the Scale tool
The Scale tool is useful for:
- Resizing sketch profiles – Make an existing profile larger or smaller without redrawing it.
- Creating size variations – Adjust a sketch design to fit different dimensions.
- Changing proportions – Stretch or compress sketch geometry along individual axes.
- Scaling around a reference point – Control how geometry expands or contracts relative to a chosen center.
- Use Uniform scaling when you need to preserve the original proportions.
- Move the gizmo center before scaling when the resize should be anchored to a particular location.
- Check existing sketch constraints and dimensions if the geometry does not resize as expected.
| Issue | What to check |
| The sketch changes proportions unexpectedly. | Check whether Type is set to Non-Uniform. Use Uniform to preserve proportions. |
| The sketch scales from the wrong point. | Reposition the gizmo center before adjusting the scale. |
| The sketch does not resize as expected. | Check the selected sketch items and any constraints or dimensions that may restrict changes. |
