Sketch menu: Spline tool
Learn how to create and edit Fit Point and Control Point splines using a mouse, trackpad, or pen.
What is the Spline tool?
You can use the Spline Spline tool icon tool to create smooth curves for rounded profiles and organic shapes. Choose one of two spline types:
  • Fit Point – Creates a curve that passes through the points you define. Moving one point can affect the shape of other parts of the curve.
  • Control Point – Creates a curve guided by a control polyline. Move its control points to shape the curve without dragging the curve itself.
How to use the Spline tool
Create a Fit Point spline
  1. Define your sketch plane.
  2. Go to Sketch > Spline > Fit.
  3. Create the curve using your input method:
    • Keyboard and mouse/trackpad: Click to place points that the curve should pass through. Continue placing points to shape the spline.
    • Touch and pen: Draw a curve segment, then lift your pen. Start from the previous segment's endpoint to draw connecting curve segments.
  4. To finish drawing with a mouse or trackpad, press Escape or Backspace. With a pen, lift your pen to finish the current segment.
Create a Control Point spline
  2. Go to Sketch > Spline > Control.
  3. Place successive control points to create a connected control polyline that guides the curve:
    • Keyboard and mouse/trackpad: Click to place points along the control polyline.
    • Touch and pen: Draw connecting lines to form the control polyline.
Edit a spline
After creating a spline, you can change its shape by editing its points.
  • Move points – Select and drag a point to reshape the spline. With a mouse or trackpad, exit the Spline tool first by pressing Escape. For a Control Point spline, move the control points rather than the curve itself.
  • Adjust Fit Point curvature – Select a fit point and drag its handles to change the curvature at that point.
  • Add points – With a mouse or trackpad, right-click the curve to open the context menu, then select New Spline Point. With a pen, select the curve and long-tap it.
  • Remove points – Select a point and choose Delete.
  • Break or join splines – Select a point and use the Break/Join badge. For more about sketch relationships, visit Constraints.
Tip: To create a tangent connection between a Control Point spline and a straight line, align the spline's control polyline with the neighboring line at the connection.
Sketch History settings
When to use the Spline tool
  • Trace a particular path – Use Fit Point splines when the curve needs to pass through specific locations.
  • Shape smooth outlines – Use Control Point splines when you want to adjust the overall flow of a curve through its control polyline.
  • Create organic profiles – Use either spline type for flowing shapes that are difficult to construct from straight lines and arcs alone.
  • Choose the spline type based on how you want to edit. Fit Point splines pass through their points, while Control Point splines are shaped by a guiding polyline.
  • Adjust the appropriate points. Move fit points and their handles for a Fit Point spline; move the control points for a Control Point spline.
  • Check neighboring geometry. When joining a spline to another sketch item, review the connection and any relevant constraints.
Issue What to check
Moving one Fit Point changes more of the curve than expected. Fit Point splines are continuous curves, so changes to one point can affect nearby sections. Adjust other points or their handles as needed.
Dragging the Control Point spline's curve doesn't reshape it as expected. Select and move its control points rather than the curve itself.
You can't edit a point with a mouse or trackpad. Press Escape to exit the active Spline tool, then select the point.
A spline doesn't connect smoothly to a straight line. Check the endpoints and, for a Control Point spline, the alignment of its control polyline with the line.
96 out of 125 found this helpful
