Sketch menu: Automatic Line/Arc tool
Learn how to draw lines and arcs using pen gestures, switch between them, and choose a specific drawing mode when needed.
What is the Automatic Line/Arc tool?
You can use the Automatic Line/Arc Automatic Line/Arc icon tool to draw straight lines and arcs with a pen. In Automatic mode, Shapr3D switches between line and arc drawing based on your pen gestures.
This drawing method is specific to pen input. You can also choose Line or Arc manually when you want to draw only one type.
How to use the Automatic Line/Arc tool
Draw lines and arcs automatically
  1. Define your sketch plane.
  2. Start drawing with your pen. Shapr3D enters sketch mode and automatically detects whether you're drawing a line or an arc.
  3. To switch between drawing a line and an arc, briefly shake your pen from side to side while keeping its tip on the screen.
Choose Line or Arc manually
  1. Go to Sketch > Line/Arc.
  2. Open the Line Type menu below Line/Arc.
  3. Change Automatic to Line or Arc.
  4. Draw with your pen using the selected type.
For detailed drawing instructions, visit the Line and Arc tool articles.
Sketch History settings
When to use the Automatic Line/Arc tool
  • Sketch continuously with a pen – Move between straight and curved sketch items without repeatedly changing drawing tools.
  • Draw only straight lines or arcs – Choose Line or Arc when you want to prevent automatic switching.
  • Check the drawing mode. If the tool isn't switching between lines and arcs, make sure Line Type is set to Automatic.
  • Choose a specific type when needed. If automatic detection isn't producing the sketch item you want, switch to Line or Arc.
Issue What to check
The tool doesn't switch between lines and arcs. Check that Line Type is set to Automatic, then use the pen wiggle gesture while sketching.
You want to draw only lines or only arcs. Open Line Type and select Line or Arc.
45 out of 54 found this helpful
