Sketch menu: Circle tool
Learn how to draw circles, set their dimensions, and manage their sketch History settings.
What is the Circle tool?
You can use the Circle Circle tool icon tool to create a closed circular sketch profile with a constant radius. Define its center and size to create circular features for your model.
How to use the Circle tool
Using the Circle tool
  1. Define your sketch plane.
  2. Go to Sketch > Circle.
  3. Draw the circle using your input method:
    • Keyboard and mouse/trackpad: Click to place the center, move your pointer to set the circle's size, then click again to finish. You can enter a dimension using the keyboard before placing the final point.
    • Touch and pen: Select the center point, then drag your pen outward to define the circle's size.
You can choose whether circle dimensions display as a radius or diameter using the Circular Annotations setting in Settings or Preferences.
Sketch History settings
When to use the Circle tool
The Circle tool is useful for creating:
  • Holes and openings – Sketch circular profiles for drilled holes or cutouts.
  • Cylindrical features – Create profiles to extrude into pins, posts, or bosses.
  • Round parts – Define the outlines of disks, wheels, or circular plates.
  • Concentric features – Draw circles with a shared center to define rings or hollow cylindrical shapes.
  • Place the center carefully. Use existing sketch references to position the circle where it belongs in your design.
  • Enter precise dimensions. When using a keyboard, type a value before finalizing the circle instead of relying only on pointer placement.
  • Check the dimension label. Confirm whether the displayed value represents the radius or diameter before entering or changing it.
Issue What to check
The circle is the wrong size. Check the dimension value and whether Circular Annotations is set to radius or diameter.
The circle is not centered where intended. Check the center point and adjust its position in the sketch.
10 out of 29 found this helpful
