Sketch menu: Ellipse tool
Learn how to create elliptical sketch profiles by defining two axes with the Ellipse tool.
What is the Ellipse tool?
You can use the Ellipse Ellipse tool icon tool to create a closed sketch profile defined by two perpendicular axes. Ellipses can have different dimensions along each axis, while circles have a constant radius.
How to use the Ellipse tool
  1. Define your sketch plane.
  2. Go to Sketch > Ellipse.
  3. Define the ellipse using your input method:
    • Keyboard and mouse/trackpad – Click to place the first point, move the pointer to define the first axis, and click to set its endpoint. Move the pointer perpendicular to the first axis and click to define the second axis.
    • Touch and pen – Select a point on the grid for the center of the ellipse, then drag to position its circumference.
With a keyboard, you can enter values for the two axes before placing their endpoints.
  • Projection – If applicable, select Edit… to modify existing projections in the sketch. To learn more, visit Project.
Sketch History settings
When to use the Ellipse tool
The Ellipse tool is useful for creating:
  • Elliptical openings and cutouts – Sketch profiles for elongated holes or openings in a design.
  • Oval-shaped parts – Create profiles for plates, covers, or other parts with elliptical outlines.
  • Rounded design features – Define elongated curved profiles that can be extruded or used with other modeling tools.
  • Layout references – Establish elliptical boundaries for positioning other sketch items.
  • Choose the sketch plane before drawing to position the ellipse in the intended orientation.
  • Use dimension values when you need precise axis lengths.
  • Check the position of the first axis before defining the second axis.
Issue What to check
The ellipse is the wrong size. Check the dimensions of both axes and adjust their values.
The ellipse is oriented incorrectly. Check the direction of the first axis, which determines the ellipse's orientation.
The ellipse is not positioned where intended. Check the placement of the ellipse and adjust its position in the sketch.
6 out of 11 found this helpful
