Learn how to use Primitives such as Box, Sphere, Cone, and Cylinder to create basic 3D shapes directly in the modeling space without sketching, adjust their dimensions, and combine them with existing bodies.
What are Primitives?
You can use Primitives to create basic solid shapes directly in the modeling space without creating a sketch first. Each primitive is defined by a placement point and a set of dimensions.
The following primitive tools are available:
- Box – Create a rectangular solid using length, width, and height.
- Sphere – Create a spherical solid using a center point and diameter.
- Cone – Create a pointed or truncated cone using base diameter, top diameter, and height.
- Cylinder – Create a cylindrical solid using diameter and height.
You can create primitives as independent bodies or combine them with existing geometry using Boolean operations.
How to use Primitives
- Go to Tools > Primitives, then select the primitive you want to create.
For other ways to access tools, visit Accessing tools. - Select a point in the modeling space to position the primitive. A preview of the shape appears with suggested dimensions.
- Adjust the dimensions of the primitive by dragging the on-canvas arrows or entering values in the dimension labels.
- Optional: Use the Result selector to choose how the primitive interacts with existing bodies.
- Optional: To adjust additional settings while the tool is active, select the active primitive tool again to open its parameter card.
- To finish, click anywhere on an empty area.
Placement and orientation
The point you select determines the position of the primitive and can also determine its orientation.
You can place a primitive on:
- Faces and edges of existing solid bodies.
- Sketch curves and closed sketch profiles.
- Grid points on the active plane.
- World axes.
- The world origin, indicated by a purple point.
When placing a primitive on a body face, its orientation follows the outward normal of the face at the selected point. This allows you to create primitives on angled or curved surfaces.
Primitives placed on the grid, world axes, or world origin are aligned with the world axes.
For primitives with a height parameter, positive and negative height values determine which direction the shape extends from its base.
Good to know: When you place a primitive on a body face or edge, its placement point remains associated with that geometry. If the referenced geometry changes, the primitive can update accordingly. Points placed on the grid, world axes, or world origin remain fixed in space.
Box
Use Box to create a rectangular solid or cube by defining its base center, length, width, and height.
How to create a box
- Go to Tools > Primitives > Box.
- Select a point to define the center of the base.
- Drag the length and width arrows or enter dimension values to define the size of the base.
- Drag the height arrow or enter a height value to define how far the box extends from the base.
- Optional: Adjust the Result setting or other parameters in the parameter card.
Box parameters
- Base Center – Define the center point of the rectangular base.
- Length – Set the length of the base. The value must be greater than zero.
- Width – Set the width of the base. The value must be greater than zero.
- Height – Set how far the box extends from the base. Use a positive or negative value to control the direction. The value cannot be zero.
- Result – Choose how the box interacts with existing bodies. See Result options.
Length and width extend symmetrically around the base center, while height extends in one direction from the base.
Tip: To create a cube, enter the same value for Length, Width, and Height.
Sphere
Use Sphere to create a spherical solid by defining its center point and diameter.
How to create a sphere
- Go to Tools > Primitives > Sphere.
- Select a point to define the center of the sphere.
- Drag the diameter arrow or enter a diameter value to adjust the size of the sphere.
Sphere parameters
- Center – Define the center point of the sphere.
- Diameter – Set the diameter of the sphere. The value must be greater than zero.
- Result – Choose how the sphere interacts with existing bodies. See Result options.
The sphere expands or contracts symmetrically around its center point when you adjust its diameter.
Cone
Use Cone to create a pointed cone, truncated cone, or tapered solid by defining its base center, base diameter, top diameter, and height.
How to create a cone
- Go to Tools > Primitives > Cone.
- Drag the base diameter arrow or enter a value to define the size of the circular base.
- Drag the height arrow or enter a height value to define how far the cone extends from the base.
- Adjust the top diameter to define the shape of the cone.
Cone parameters
- Base Center – Define the center point of the circular base.
- Base Diameter – Set the diameter of the circular base. The value must be greater than zero.
- Top Diameter – Set the diameter at the opposite end of the cone. The value must be zero or greater.
- Height – Set how far the cone extends from the base. Use a positive or negative value to control the direction. The value cannot be zero.
- Result – Choose how the cone interacts with existing bodies. See Result options.
Control the shape of a cone
The relationship between Base Diameter and Top Diameter determines the resulting shape:
| Top Diameter | Resulting shape |
| Zero | Pointed cone |
| Greater than zero but smaller than Base Diameter | Truncated cone that narrows toward the top |
| Equal to Base Diameter | Cylinder |
| Greater than Base Diameter | Truncated cone that widens toward the top |
Cylinder
Use Cylinder to create a cylindrical solid by defining its base center, diameter, and height.
How to create a cylinder
- Go to Tools > Primitives > Cylinder.
- Select a point to define the center of the circular base.
- Drag the diameter arrow or enter a diameter value to define the size of the cylinder.
- Drag the height arrow or enter a height value to define how far the cylinder extends from the base.
Cylinder parameters
- Diameter – Set the diameter of the cylinder. The value must be greater than zero.
- Height – Set how far the cylinder extends from the base. Use a positive or negative value to control the direction. The value cannot be zero.
- Result – Choose how the cylinder interacts with existing bodies. See Result options.
Shapr3D records the tools you use as steps in History, allowing you to revisit and modify them later. Each History step stores its parameters, which you can access through the parameter card.
You can adjust these parameters while using the tool or reopen the parameter card from History after completing the step.
Adjust primitive parameters
While using a primitive tool, you can open the parameter card to review or modify your selections and dimensions. To open the parameter card, select the active primitive tool again from the menu.
The available parameters depend on the selected primitive:
| Primitive | Parameters |
| Box | Base Center, Length, Width, Height, Result |
| Sphere | Center, Diameter, Result |
| Cone | Base Center, Base Diameter, Top Diameter, Height, Result |
| Cylinder | Base Center, Diameter, Height, Result |
You can enter numerical values, expressions, or variables in the dimension fields.
To learn more about using and customizing the parameter card, visit Parameter Cards.
Result options
Use Result to control whether the primitive is created as an independent body or combined with existing bodies.
The following options are available:
- New Body – Create the primitive as a separate body. This is the default option.
- Union – Combine the primitive with existing bodies. Use Union With to review or modify the selected bodies.
- Intersect – Keep the overlapping geometry between the primitive and existing bodies. Use Intersect With to review or modify the selected bodies.
- Subtract – Remove the primitive's volume from existing bodies. Use Subtract From to review or modify the selected bodies.
When you select a Boolean result, overlapping bodies are automatically included in the target selection. You can add or remove bodies from this selection in the parameter card.
You can also access the Result selector from the on-canvas dimension label when available.
Note: The Result setting remains set to New Body by default, even when the primitive overlaps existing geometry. Select a Boolean result manually if you want to combine or remove geometry.
To learn more about combining, subtracting, and intersecting bodies, visit Boolean operations.
Edit primitives in History
To modify an existing primitive step:
- Open the History sidebar.
- Select the Box, Sphere, Cone, or Cylinder step to edit to reopen its parameter card.
- Review or modify the placement point, dimensions, or Result setting used in the primitive step.
- To finish editing, click anywhere in the modeling space.
To learn more about managing and editing steps in History, visit History.
When to use Primitives
Primitives are useful when you want to create basic solid geometry without defining a sketch profile first.
Common use cases include:
- Create base geometry: Use a box or cylinder as the starting body for a more complex design.
- Block out concepts: Quickly establish the overall shape, proportions, and layout of a design using multiple primitives.
- Add design features: Combine primitives with existing bodies to create protrusions, mounting features, or other geometric details.
- Remove material: Subtract primitives from existing bodies to create holes, recesses, or cavities.
- Create tapered geometry: Use Cone to create tapered components or transitions between different diameters.
- Create spherical features: Use Sphere to create rounded components or spherical cavities.
Best practices
- Choose the placement point carefully: The selected point determines the position and can influence the orientation of the primitive.
- Use the world origin for new designs: Select the purple origin point to position your first primitive in an empty modeling space.
- Check the suggested dimensions: Initial dimensions are based on the current grid spacing when you first place the primitive. Adjust them as needed for your design.
- Use precise dimensions: Enter values directly in the on-canvas dimension labels or parameter card when working with specific measurements.
- Control the direction: Use a negative height value to extend a box, cone, or cylinder in the opposite direction from its base.
- Check the Result setting: Select the appropriate Boolean result and review the target bodies before completing the tool.
- Use History for adjustments: Reopen an existing primitive step to modify its placement or dimensions without recreating the body.
Troubleshooting
| Issue | What to check |
| The primitive appears in the wrong position. | Review the selected Base Center or Center point in the parameter card. |
| The primitive extends in the wrong direction. | Check the selected placement point and the positive or negative Height value. |
| The initial primitive is too large or too small. | Suggested dimensions depend on the grid spacing when the placement point is first selected. Adjust the dimensions using the on-canvas controls or parameter card. |
| A dimension field displays an error. | Length, Width, Diameter, and Base Diameter must be greater than zero. Height cannot be zero, and Top Diameter must be zero or greater. |
| The cone does not have a pointed tip. | Set Top Diameter to zero to create a pointed cone. |
| The primitive remains separate from existing bodies. | Result is set to New Body by default. Select Union, Intersect, or Subtract as needed. |
| The Boolean result does not affect the intended bodies. | Check that the primitive overlaps the intended bodies and review the target body selection in the parameter card. |
| The placement point is missing when editing in History. | The referenced geometry may have been deleted. Select a new Base Center or Center point. |
| Area selection or selection from Items Manager is unavailable. | Select the placement point directly in the modeling space. Primitive tools do not support area selection or selection from Items Manager for placement points. |
