Learn how to use Intersection Curve to create standalone 3D curves where faces, bodies, and planes intersect, without modifying the original geometry.
What is the Intersection Curve tool?
You can use the Intersection Curve tool to create standalone 3D curves along the intersections between selected faces, bodies, and planes.
Unlike sketch curves, intersection curves are not restricted to a sketch plane. They can extend through three-dimensional space, following the shape of the intersecting geometry.
The tool creates a separate curve at each intersection without modifying the original solid bodies. You can use the resulting curves as paths or guide curves in subsequent modeling operations.
If multiple curves are generated in a single operation, they are automatically organized into a new folder named Curves in the Items panel.
Supported geometry
Intersection Curve uses two sets of geometry to determine where curves are generated:
| Selection | Supported geometry |
| Intersect With |
| Faces to Intersect |
Construction planes and world planes are treated as infinite surfaces. Their visible boundaries do not limit where intersection curves can be generated.
Note: Mesh bodies are not supported by the Intersection Curve tool.
How to use the Intersection Curve tool
- Go to Tools > Intersection Curve.
For other ways to access tools, visit Accessing tools. - Select the faces or planes you want to intersect with. These are added to the Intersect With selection.
- Select the faces or solid bodies where you want to generate intersection curves. These are added to the Faces to Intersect selection. A preview of the resulting curves appears.
- Optional: Select the on-canvas badge of a selected face to move it from one selection set to the other.
- Optional: To review or modify your selections while the tool is active, select Intersection Curve again to open the parameter card.
- To finish, click anywhere on an empty area.
Good to know: You can select geometry directly in the modeling space, use area selection, or select supported items from the Items panel.
Shapr3D records the tools you use as steps in History, allowing you to revisit and modify them later. Each History step stores its parameters, which you can access through the parameter card.
You can adjust these parameters while using the tool or reopen the parameter card from History after completing the step.
Adjust Intersection Curve parameters
While using Intersection Curve, you can open the parameter card to review or modify your selections. To open the parameter card, select Intersection Curve again from the menu.
The following parameters are available:
- Intersect With – Select or modify the faces or planes used to define the intersections.
- Faces to Intersect – Select or modify the faces or solid bodies on which intersection curves are generated.
To learn more about using and customizing the parameter card, visit Parameter Cards.
Edit Intersection Curve in History
To modify an existing Intersection Curve step:
- Open the History sidebar.
- Select the Intersection Curve step to edit to reopen its parameter card.
- Review or modify the faces, bodies, or planes used in the Intersection Curve step.
- To finish editing, click anywhere in the modeling space.
To learn more about managing and editing steps in History, visit History.
When to use the Intersection Curve tool
Intersection Curve is useful when you need to:
- Generate cross-sectional curves: Intersect a solid body with a plane to create a precise outline of its cross-section without splitting the body.
- Identify surface intersections: Create curves that follow the exact locations where two surfaces intersect.
- Create guide curves: Use intersections between existing geometry to define the shape of subsequent modeling operations.
- Define modeling paths: Generate curves that follow complex geometry for use as paths in other tools.
- Extract reference geometry: Create standalone curves from existing solid geometry without modifying the original bodies.
Best practices
- Check that the selected geometry intersects: The selected faces, bodies, or planes must intersect to generate a curve.
- Use planes for cross-sections: Select a construction plane or world plane to generate cross-sectional curves without modifying the original body.
- Select only the geometry you need: Select individual faces instead of entire bodies when you want to generate curves from specific intersections.
- Review both selection sets: Use the on-canvas badges or parameter card to ensure that the selected geometry is assigned to the intended selection set.
- Check for multiple curves: A single operation can generate multiple curves when the selected geometry intersects in more than one location. Review the Curves folder in the Items panel to locate the resulting curves.
- Use History for adjustments: Reopen an existing Intersection Curve step to modify its selections without recreating the curves manually.
Troubleshooting
| Issue | What to check |
| Unable to select geometry | Check that the geometry is supported by the active selection set. Planes can only be selected under Intersect With, and mesh bodies are not supported. |
| Geometry is assigned to the wrong selection set | Select the on-canvas badge of the selected face to move it to the other selection set, or modify the selections in the parameter card. |
| Selected items do not intersect | Check that the selected geometry intersects. Adjust the position of the geometry or select different faces, bodies, or planes. |
| Selected items are coplanar | The selected geometry lies on the same plane. Select geometry that intersects along a distinct curve. |
| The intersection is too small | Adjust the position of the intersecting geometry or select geometry with a larger intersection. |
| Self-intersecting curves cannot be generated | Adjust the selected geometry to avoid generating curves that cross themselves. |
| More curves are generated than expected | Check whether the selected geometry intersects in multiple locations. Select individual faces instead of entire bodies to limit the intersections. |
| Cannot generate curve | Review both selection sets and check that the selected geometry forms a valid intersection. |
