Tools menu: Bridge Curve tool
Learn how to use Bridge Curve to create standalone 3D curves connecting existing geometry, adjust their shape, and control the continuity at each end.
What is the Bridge Curve tool?
You can use the Bridge Curve tool to create a standalone curve connecting two existing edges or curves. You can control where the bridge curve connects to the selected geometry and how smoothly it transitions at each end.
Unlike sketch curves, bridge curves are not restricted to a sketch plane. They can extend through three-dimensional space, allowing you to create connections between geometry on different planes or at different orientations.
The resulting geometry is a standalone curve without thickness or surface area. You can use it as a path or guide curve in subsequent modeling operations.
Supported geometry
You can create a bridge curve between two of the following:
  • Body edges
  • Existing standalone curves
  • Sketch curves
Both selections must be different, open edges or curves. Closed geometry, such as circles or closed loops, cannot be used.
How to use the Bridge Curve tool
  1. Go to Tools > Bridge Curve.
  2. Select the first edge or curve near the end where you want the bridge curve to start.
  3. Select the second edge or curve near the end where you want the bridge curve to connect. A preview of the bridge curve appears.
  4. Use the on-canvas controls to adjust the shape of the bridge curve at either end:
    • Select the Continuity badge to control how smoothly the curves connect.
    • Select the Reverse Direction badge to reverse the direction in which the bridge curve extends from the selected geometry.
    • Drag the Magnitude arrow to adjust how far the bridge curve extends before bending toward the other end.
    • Drag the Join Position control along the selected edge or curve to change the attachment point.
  5. Optional: To adjust additional settings or enter precise values while the tool is active, select Bridge Curve again to open the parameter card.
  6. To finish, click anywhere on an empty area.
Bridge Curve controls
You can independently adjust the shape and connection of the bridge curve at its start and end. Each end has its own Continuity, Reverse Direction, Magnitude, and Join Position settings.
These settings are available through the on-canvas controls and the parameter card.
Continuity
Continuity determines how smoothly the bridge curve connects to the selected geometry. You can choose a different continuity level for each end of the bridge curve.
  • G0 (Positional) – Connects the curves at a shared point without matching their directions. The connection can form a sharp corner.
  • G1 (Tangent) – Matches the direction of the curves at the connection point, creating a smooth transition without a sharp corner.
  • G2 (Curvature) – Matches both the direction and curvature of the curves at the connection point, creating a more gradual transition.
By default, both ends of the bridge curve use G2 continuity.
Good to know
  • Setting both ends to G0 creates a straight line between the attachment points.
  • Higher continuity levels can produce wider or more pronounced curves. If the resulting shape is too exaggerated, try changing one or both ends from G2 to G1.
  • Magnitude and Reverse Direction do not affect an end with G0 continuity.
For more information about continuity and how it affects geometry, visit Understanding curve and surface continuity.
Reverse Direction
Reverse Direction controls which direction the bridge curve extends from the selected edge or curve.
  • Off: The bridge curve extends outward, continuing the direction of the selected geometry.
  • On: The bridge curve extends in the opposite direction, allowing it to bend back toward the selected geometry.
Use the Reverse Direction badge at either end to explore different curve shapes without changing the selected geometry or attachment points.
Reverse Direction is turned off by default and affects only ends with G1 or G2 continuity.
Magnitude
Magnitude controls how far the bridge curve extends along its connection direction before bending toward the other end.
Magnitude is a unitless multiplier of the automatically calculated value, rather than a fixed distance.
  • 1: Uses the automatically calculated magnitude. This is the default value.
  • Greater than 1: Extends the curve farther along its connection direction before bending away.
  • Between 0 and 1: Makes the curve bend away sooner, creating a shorter-reaching shape at that end.
Drag the Magnitude arrow or enter a value in the parameter card to fine-tune the shape of the bridge curve.
Note: Magnitude must be greater than 0 and only affects ends with G1 or G2 continuity. When connecting to tightly curved geometry with G2 continuity, increasing Magnitude may have a more limited effect on the resulting shape.
Join Position
Join Position determines where the bridge curve attaches to the selected edge or curve. It uses a value between 0 and 1, representing a position along the length of the selected geometry.
  • 1: Connects to the endpoint nearest to where you selected the edge or curve. This is the default value.
  • 0.5: Connects to the midpoint along the length of the selected edge or curve.
  • 0: Connects to the opposite endpoint.
You can drag the Join Position control along the selected geometry or enter a precise value in the parameter card.
Note: Connecting a bridge curve between the endpoints of an existing edge or curve does not split or trim the original geometry.
Shapr3D records the tools you use as steps in History, allowing you to revisit and modify them later. Each History step stores its parameters, which you can access through the parameter card.
You can adjust these parameters while using the tool or reopen the parameter card from History after completing the step.
Adjust Bridge Curve parameters
While using Bridge Curve, you can open the parameter card to review or modify your selections and settings. To open the parameter card, select Bridge Curve again from the menu.
The following parameters are available:
  • Start Curve – Review or modify the edge or curve used to define the start of the bridge curve.
  • End Curve – Review or modify the edge or curve used to define the end of the bridge curve.
  • Start / End – Independently adjust the following parameters at each end of the bridge curve:
    • Join Position – Specify the attachment point along the selected edge or curve.
    • Continuity – Control how smoothly the bridge curve connects to the selected geometry.
    • Magnitude – Adjust how far the bridge curve extends along its connection direction before bending away.
    • Reverse Direction – Reverse the direction in which the bridge curve extends from the selected geometry.
For a detailed explanation of these parameters, refer to Bridge Curve controls.
To learn more about using and customizing the parameter card, visit Parameter Cards.
Edit Bridge Curve in History
To modify an existing Bridge Curve step:
  1. Open the History sidebar.
  2. Select the Bridge Curve step to edit to reopen its parameter card.
  3. Review or modify the selected curves and their connection settings used in the Bridge Curve step.
  4. To finish editing, click anywhere in the modeling space.
To learn more about managing and editing steps in History, visit History.
When to use the Bridge Curve tool
Bridge Curve is useful when you need to:
  • Connect geometry in 3D space: Create curves between edges or curves located on different planes without creating additional sketches.
  • Create smooth transitions: Connect existing geometry while controlling the direction and curvature at each end.
  • Create guide curves: Build a framework of curves to control the shape of geometry in subsequent modeling operations.
  • Define paths: Create connecting curves that can be used as paths in subsequent modeling operations.
  • Explore complex shapes: Adjust curve direction, magnitude, and continuity to explore different design variations without modifying the original geometry.
Best practices
  • Select each edge or curve near the endpoint you want to connect to minimize the need to adjust Join Position.
  • Start with the default continuity and magnitude settings, then adjust them based on the resulting shape.
  • Use G1 or G2 continuity when you need smooth transitions between curves.
  • Use Reverse Direction before adjusting Magnitude if the bridge curve extends in an unintended direction.
  • Adjust the settings at each end independently to achieve the desired shape.
  • Inspect the resulting curve from different viewing angles, especially when connecting geometry on different planes.
Troubleshooting
Issue What to check
Unable to select an edge or curve Make sure the geometry is open and select it directly in the modeling space. Area selection and selection from the Items panel are unavailable while using Bridge Curve.
Invalid selection Make sure you have selected two different open edges or curves. If editing an existing History step, check that both selections are still valid.
Bridge curve connects to the wrong endpoint Adjust Join Position or reselect the geometry near the intended endpoint.
Bridge curve extends in the wrong direction Toggle Reverse Direction at the affected end.
Bridge curve bends too far or creates an unexpected loop Reduce Magnitude, adjust Reverse Direction, or try a lower continuity level at one or both ends.
Magnitude or Reverse Direction has no effect Check the Continuity setting. These parameters only affect ends with G1 or G2 continuity.
Bridge curve appears as a straight line Check whether both ends use G0 continuity. Change one or both ends to G1 or G2 to control the shape of the connection.
Invalid Magnitude value Enter a value greater than 0.
Invalid Join Position value Enter a value between 0 and 1.
Unable to create a bridge curve with the current settings Try adjusting the Join Position, Continuity, Magnitude, or Reverse Direction settings. Check that the selected geometry is still valid.
0 out of 0 found this helpful
