Learn how to use the Chamfer tool to create beveled edges on 3D bodies, choose between equal and two-distance chamfers, and edit the result using parameter cards and History.
What is the Chamfer tool?
You can use the Chamfer tool to replace sharp edges of a 3D body with angled, beveled faces. Chamfers are useful for removing sharp corners, creating lead-in edges for assembly, and refining the appearance of a model.
Chamfer creates beveled edges with flat transitions between adjacent faces, while Fillet creates rounded transitions. You can apply chamfers to one or more selected body edges and control the setback distances. To learn more, visit Tools menu: Fillet tool.
| Chamfer | Fillet |
How to use the Chamfer tool
Using the Chamfer tool
To create a chamfer:
- Go to Tools > Chamfer.
For other ways to open the tool, visit Accessing tools. - Select the body edge or edges you want to chamfer.
- Drag the arrow to adjust the chamfer, or enter a value in the dimension field.
- Optional: To change the chamfer type or review other settings, select Chamfer again while the tool is active to open its parameter card.
- To finish and exit the tool, click anywhere in an empty area of the modeling space.
Chamfer and Fillet in direct modeling
When you select a body edge directly in the modeling space, you can create either a chamfer or a fillet by dragging the arrow in different directions:
- Chamfer: Drag the arrow toward the body to create a beveled edge.
- Fillet: Drag the arrow away from the body to create a rounded edge.
Once you start creating a chamfer or fillet, Shapr3D activates the corresponding tool. You can continue adjusting its parameters, but you can no longer switch between Chamfer and Fillet within the same operation.
Chamfer types
Use the Type setting to choose how the bevel is measured. Chamfer supports two types:
Equal Distance
Equal Distance creates a bevel with the same setback distance on both adjacent faces. For an edge formed by two perpendicular faces, equal setbacks produce a 45° bevel. Enter the desired setback in the Distance field.
Two-Distance
Two-Distance lets you set different setbacks on the two adjacent faces. Use Distance #1 and Distance #2 to control each side independently. This is useful when the bevel needs an asymmetric profile.
Adjust Chamfer parameters
While Chamfer is active, select Chamfer again to open the parameter card. The available settings are:
- Edge – Review or change the body edges selected for the chamfer.
- Type – Switch between Equal Distance and Two-Distance.
- Distance – For Equal Distance, set the setback applied to both adjacent faces.
- Distance #1 and Distance #2 – For Two-Distance, set the setback on each side of the selected edge independently.
- Include Tangent Edges – Turn on to include connected tangent edges in the chamfer operation. Turn off to limit the operation to the selected edges.
Edit Chamfer in History
To modify a chamfer after completing the operation:
- Open the History sidebar.
- Select the Chamfer step you want to edit to open its parameter card.
- Change the selected edges, chamfer type, distances, or tangent-edge inclusion as needed.
- To finish editing, click anywhere in the modeling space.
When to use the Chamfer tool
Common Chamfer use cases
- Remove sharp edges – Add a flat bevel to exposed edges of a part.
- Create assembly lead-ins – Bevel an entrance edge to help guide mating parts into position.
- Refine a model's appearance – Use consistent chamfers to add deliberate edge details.
- Create asymmetric bevels – Use Two-Distance when each side needs a different setback.
Chamfer vs. Fillet
Both tools modify existing body edges, but they produce different transitions:
- Chamfer creates a flat, angled face between neighboring faces.
- Fillet creates a rounded transition, with additional controls for continuity and corner blending.
To learn more about rounded edge transitions, visit Tools menu: Fillet tool.
Best practices
- Start with a small distance – Increase the setback gradually when working near narrow faces or other features.
- Choose the appropriate type – Use Equal Distance for symmetric bevels and Two-Distance for independent setbacks.
- Review tangent-edge inclusion – Check whether connected tangent edges should be included in the same operation.
- Use History for revisions – Edit an existing Chamfer step when you need to refine its dimensions or edge selection.
Troubleshooting common issues
| Issue | What to check |
| More edges are chamfered than expected | Review Include Tangent Edges and the selected edges. |
| The bevel is not symmetric | Check whether Two-Distance is selected and compare Distance #1 with Distance #2. |
| The chamfer cannot be created at the entered distance | Try a smaller distance and check the nearby geometry for limited space. |
| The wrong edges are modified | Open the parameter card and review the Edge selection. |
