Keyboard shortcuts, gestures, and hotkeys
You can navigate, edit, sketch, and model intuitively with your preferred input device in Shapr3D. On compatible hardware, using touch and pen activates basic gestures while a keyboard allows you to use hotkeys or do quick command searches icon-search-win.png. Follow the guidelines below to learn how to use your different input devices to interact with Shapr3D.
Getting started
Windows
Shapr3D on Windows supports the simultaneous use of all input methods without any additional configuration. Some elements of the UI slightly change depending on the input method you are using, but no manual configuration is required.
iPadOS
To get started using a keyboard with a mouse or trackpad,
If you're using a mouse,
If you're using a trackpad,
macOS
Shapr3D on macOS supports keyboard and mouse usage. No manual configuration is required.
Single Key Action setting
In Shapr3D, you can choose between two ways to quickly access commands and tools via the keyboard: Hotkeys and Command Search.
Hotkeys
When prioritizing hotkeys, you can select tools and commands with a single key press or a simple key combination. On new installations of Shapr3D, the hotkeys are enabled by default and accessing command search requires an extra hotkey (X).
Note: If you have an older version of Shapr3D, your default setting might still be set to trigger command search as you start to type.
When prioritizing command search, you can start typing in the name of the command and select from the search box that pops up, which takes a bit more keystrokes but can be easier to learn.
Choose a Single Key Action
To choose between Hotkeys and Command Search:
  1. Go to Settings or Preferences > Single Key Action.
  2. Choose your preferred action.
Customize keyboard shortcuts
You can customize your keyboard shortcuts to modify and assign shortcuts to the actions you use most, allowing you to streamline your workflow and enhance productivity.
To customize keyboard shortcuts:
  1. Go to Settings or Preferences.
  2. Open the keyboard shortcuts settings:
    • Windows/iPadOS: Select Customize Keyboard Shortcuts…
    • macOS: Under General, find Keyboard shortcuts and then select Customize…
  3. Choose the category where you want to create or modify a keyboard shortcut.
  4. Find the specific action, then press the keys you want to assign as the shortcut to auto-populate the field.
  5. To finish, select Save Changes.
Cheat sheet
Below is a cheat sheet of hotkeys, shortcuts, and basic gestures for various input devices. You can also find this cheat sheet in the Shapr3D modeling space:
  • Windows: Select Help icon-help-mac.png > Keyboard Shortcuts, or long-press the CTRL key.
  • iPadOS: Select Help icon-help-mac.png > Keyboard Shortcuts, or long-press the Command key.
  • macOS: Select Help icon-help-mac.png > Keyboard Shortcuts.
Hotkeys are highlighted in blue. To use hotkeys, choose Hotkeys as your Single Key Action
Tool/Action
Gesture/Shortcut/Hotkey
Dashboard
New project
⌘ N
Import to current project
⇧ ⌘ I
Import as new project
⌥ ⌘ I
New folder
⇧ ⌘ N
New folder with selection
⌥ ⌘ N
Rename folder or project
⌥ ⌘ R
Duplicate project
⌘ D
Go back
Go forward
Go to enclosing folder
Open folder
Go to Recents
Shift + ⌘ + 1
Go to Projects
Shift + ⌘ + 2
Delete a project or folder
⌘+Backspace OR Delete key
Expand folder
Expand folder and subfolders
Collapse folder
Collapse folder and subfolders
Go back to the Dashboard
⌘ W
Copy projects/folders
⌘ C
Paste projects/folder
⌘ V
Navigation
Orbit (Rotate camera)
Mouse/Magic Mouse: Secondary click (right-click) and drag the mouse
Trackpad:
• iPadOS/macOS: Pan with two fingers on the trackpad.
• Windows: Hold down CTRL + Shift and pan one finger on the trackpad
Note: These controls use the Shapr3D Default navigation preset. To learn more, go to Navigation Presets.
Pan (Move camera)
Mouse: Hold down the middle mouse button and drag the mouse. Alternatively, hold the Shift key and use secondary click (right-click) to drag the mouse.
Magic Mouse: Hold the Shift key and use secondary click (right-click) to drag the mouse.
Trackpad:
• iPadOS/macOS: Hold down the Shift key and pan with two fingers on the trackpad.
• Windows: Hold down CTRL + ALT and pan one finger on the trackpad.
Zoom camera
Mouse: Scroll with the mouse wheel
Magic Mouse: Hold the Control key and pan up/down with your finger on the mouse.
Trackpad: Pinch in or out with two fingers on the trackpad.
Zoom to face
Hover over a face and press the Space bar.
Rotate 2D view by 90 degrees
Click the right or left arrow above the Orientation Cube.
iPadOS/macOS Windows
Reset view
⌘ 1  CTRL + 1
Switch to front view
⌘ 2  CTRL + 2
Switch to back view
⌘ 3  CTRL + 3
Switch to top view
⌘ 4
 CTRL + 4
Switch to bottom view
⌘ 5  CTRL + 5
Switch to right view
⌘ 6  CTRL + 6
Switch to left view
⌘ 7  CTRL + 7
Sketching
Start sketch
Click anywhere in the modeling space.
Remove last-placed point and finish sketch
Escape or Backspace ⌫ key.
Set final endpoint and finish sketch
Enter key
Add fit point to spline
Long-click anywhere on the spline
Sketch Tools
Constraint Settings
Arc
A
Parallel
⇧ Shift + A
Circle
C
Concentric
⇧ Shift + C
Polygon
G
Equal
⇧ Shift + E
Spline
I
Horizontal/Vertical
⇧ Shift + V
Line
L
Coincident
⇧ Shift + N
Offset Edge
O
Lock/Unlock
⇧ Shift + L
Rectangle
R
Midpoint
⇧ Shift + M
Trim
T
Perpendicular
⇧ Shift + P
Symmetry
⇧ Shift + S
Tangent
⇧ Shift + T
Modeling
Tools
Boolean Operations
Extrude
E
Union
⌘ U or CTRL + U
Fillet/Chamfer
F
Subtract
⌘ B or CTRL +B
Shell
H
Intersect
⌘ I or CTRL + I
Move/Rotate
M
Translate
N
Project
P
Scale
S
Revolve
V
Sweep
W
Edit
Search for commands
X (if hotkeys are enabled)
or
⌘ F
or
CTRL + F
Undo
⌘ Z   CTRL + Z
Redo
⇧ ⌘ Z   Shift + CTRL + Z
Delete
⌫   Backspace or Delete key
Finish sketch
⏎   Enter key
Selection
Select full object
Double-click the object
Select all
⌘ A or CTRL + A
Select Through
iPadOS/macOS ⌘ ⇧ S
Windows: CTRL + Shift + S
Deselect all
iPadOS/macOS: Esc or ⌘ .
Windows: CTRL + Shift + A or Esc
Select single item
Click the item.
Select multiple items
Hold down the ⇧ Shift key and click each item.
Select area
Click anywhere in the modeling space and drag the arrow to the right or left.
Cycle through selection filters
⇥ (Tab key)
Filter selection for bodies only
B
Filter selection for edges only
E
Filter selection for faces only
F
2D Drawings
Update 2D drawing
iPadOS/macOS: ⌘ R
Windows: CTRL + R
Project Sidebar
Show/hide Project Sidebar
iPadOS/macOS: ⇧⌘ \
Windows: CTRL + Shift + \
Jump to last visited document
iPadOS/macOS: ⇧⌘ [ OR ⇧⌘ ]
Windows: CTRL +Tab
Close
Esc key
Show/Hide Items
iPadOS/macOS: ⌘ ⌥ S
Windows: CTRL + ALT + S
Show/Hide History
iPadOS/macOS: ⌘ ⌥ H
Windows: CTRL + ALT + H
Items Manager
Select all items/folders
iPadOS/macOS: ⌘ A
Windows: CTRL + A
Collapse all expanded folders
macOS: ⌥ L
Windows: CTRL + ALT + L
Unfocus or deselect items/folders
Esc key
Delete selected items/folders
iPadOS/macOS: ⌘ ⌫
Windows: Delete key
History Sidebar
Select all steps
iPadOS/macOS: ⌘ A
Windows: CTRL + A
Collapse all steps
macOS: ⌥ L
Suppress selected steps
iPadOS/macOS: ⌫
Windows: Delete or Backspace key
Unfocus or deselect steps
Esc key
Delete selected steps
iPadOS/macOS: ⇧ ⌫
Windows: Shift + Delete key
Variables
Create variables
iPadOS/macOS: ⇧⌘ V
Windows: CTRL + Shift + V
Screenshots
Copy to clipboard
iPadOS/macOS: ⇧⌘ C
Windows: CTRL + Shift + C
1685 out of 2348 found this helpful
