Learn how to repeat sketch items along one or two straight directions with Pattern – Linear.
What is the Pattern – Linear tool?
You can use the Pattern – Linear tool to repeat selected sketch items along one or two straight directions. The pattern instances maintain a sketch pattern constraint relationship.
For circular patterns, use the Pattern – Circular tool . To learn how to pattern 3D geometry, visit Transform menu: Pattern tool .
How to use the Pattern – Linear tool
- Within a sketch, go to Sketch > Pattern – Linear .
For other ways to access tools, visit Accessing tools . - Select the sketch items you want to pattern.
- Use the inline Distance Type control to choose Total or Spacing .
- Drag the gizmo control to create the pattern, then enter a precise distance using the dimension label.
- Set Quantity to control the number of pattern instances.
- To create a pattern in a second direction, adjust the second gizmo arrow and its distance and quantity.
- To finish, select an empty area of the grid.
Sketch patterns include a pattern constraint that maintains relationships between instances. Learn more about the Sketch pattern constraint .
Creating a sketch pattern does not create a separate Pattern step in History . You can still reopen the existing Sketch step to review or modify its settings:
- Plane – Select Edit… or Select… to change the plane or face containing the sketch, then select Done.
- Projection – If applicable, select Edit… to modify existing projections in the sketch.
When to use the Pattern – Linear tool
Use this tool for:
- Repeated openings – Lay out evenly spaced holes or cutouts.
- Grids and arrays – Arrange repeated profiles in rows and columns.
- Regular details – Repeat ribs, slots, or decorative geometry along a straight path.
- Choose Total for an overall extent or Spacing for the gap between instances.
- Check the sketch pattern constraint when adjusting individual instances after patterning.
| Issue | What to check |
| The copies are spaced incorrectly. | Check whether Total or Spacing is selected and verify the dimension value. |
| The pattern has too many or too few instances. | Check the Quantity value. |
| The pattern extends in the wrong direction. | Check the gizmo arrow direction and the second direction, if used. |
