5.510 - Point selection workflow
Model more accurately with an improved point selection workflow:
Point selection workflow is now more accurate, allowing you to select 3D points with more precision when creating construction geometries or defining translate operations.
Simply add a new construction geometry and use the new guide points to help you find exact points.
Before:
After:
25 out of 32 found this helpful
