Shapr3D release updates
26.210 - Thread tool, sketch tools, and import updates
The Thread tool is here. Create and customize geometric threads, refine sketches with the Slot and Extend tools, and reuse existing models with 3MF import. Plus, explore new Visualization materials and interface improvements to streamline your modeling workflow.
26.201 - Shapr3D is now available on iPhone
Take your designs anywhere with Shapr3D on iPhone. View, inspect, and present your 3D models on the go, with full modeling capabilities coming to iPhone Duo in November.
26.190 - Introducing Fill Tool (Beta)
Take on more complex surface modeling workflows with greater control over shape and continuity using the new Fill tool, now in beta.
26.180 - Parameter Cards Rollout + Stability Improvements
Preview Parameter Cards—now rolling out to a limited group of users—alongside general bug fixes and stability improvements across Shapr3D.
26.170 - Multicolor Support for Slicer Integrations from Visualization
Send colorful designs directly to your slicer with automatic color detection from Visualization.
26.161 - Direct Export to Bambu Lab and OrcaSlicer on desktop
Export designs directly to Bambu Studio or OrcaSlicer on desktop to prepare prints and send models straight to your printer.
26.160 - Stability and Bug Fixes
This release focuses on bug fixes and stability improvements. Update to get a smoother experience and stay tuned for what’s coming next.
26.150 - Stability and Bug Fixes
26.140 - Stability and Bug Fixes
26.120 - Prusa Slicer integration and Dashboard Search
Export models directly into the Prusa 3D printing ecosystem and locate your workspace folders instantly via the Dashboard search bar.
26.110 - Visualization materials, Decal workflows, and Construction tool updates
Add realistic interior material finishes, apply multiple decals non-destructively, and reference reference geometry on STL meshes.
26.100 - Auto-Boolean Revolve and Improved Decals
Speed up workflows with automatic Boolean choices in the Revolve tool and gain control with a cylindrical projection toggle for decals.
26.90 - X-Ray mode, seamless Decals, and improved construction tools
Gain internal visibility with the new X-Ray display mode, wrap decals seamlessly across multiple adjacent faces, and explore a dedicated Construct menu.
26.80 - Decals in Visualization
Bring models to life with Decals for logos and labels, and enjoy improved selection visibility and section view persistence.
26.70 - Wireframe Silhouettes & Vertical AR Snapping
Experience better model definition with wireframe silhouettes and place models on vertical surfaces in AR.
26.60 - Custom materials from images
Import .png and .jpeg images as custom materials and experience optimized performance when working with large assemblies.
26.50 - Improved Section Views and Wrap & Emboss Gizmo
Isolate cross-sections with Section Only mode and use new in-space gizmos for the Wrap & Emboss tool.
26.40 - Display edges in Visualized shader
Improve structural clarity with edge visibility in Visualization and discover new realistic material finishes.
26.30 - Wrap & Emboss tool is here
Wrap sketches around curved surfaces with the new Wrap & Emboss tool and experience up to 70% faster project imports.
26.20 - Screenshot Resolution Presets and Options
Capture higher-quality visuals with new resolution presets including Full HD, 4K, and 8K options.
26.10 - Custom materials in Visualization
Import custom materials, sketch with world axis constraints, and reuse designs faster with multi project importing.
26.0 – Scale, Orientation, and Twist controls for Sweep
Refine sweep results with new parameter controls in the History sidebar.
5.1010 – Project imports and smarter sketch snapping
Import projects directly and sketch more accurately with expanded snapping behavior.
5.1000 – Display modes and grid visibility
Control your workspace and visuals more easily with updates to Display Modes and grid visibility.
5.990 – Upgraded import performance
Experience faster, more reliable imports with enhanced performance for Siemens NX, Solid Edge, and SolidWorks formats.
5.980 – Easier access to project spaces
Switch between Modeling, Visualization, and Drawings directly in the workspace.
5.970 - Split Body Upgrades, Shared Projects, and Navigation Updates
Split bodies with multiple tools, share projects directly with collaborators, and match navigation to your preferred CAD system.
5.960 - Section View Interference, AI Capture, and In-app Access Management
Check for interferences directly in Section View, generate AI-enhanced images in Visualization, and manage project access without leaving the app.
5.950 - Material Search, Shader Selection, and Surface Analysis
Find materials faster, inspect surfaces with new options, and control lighting in your scenes.
5.940 - Visualization updates
Bring more detail and clarity to your renders with new materials and improved ways to work with them in Visualization.
5.930 – Sketching upgrade and Dashboard updates
Sketch faster in complex files, share designs more easily, and manage project storage with new options in Settings.
5.920 - Access sharing during export
Share projects from the Export modal, work with smarter offset constraints, and navigate design history more smoothly.
5.910 - Dashboard details, Measure mode, and storage optimization
Stay organized and work more efficiently with updates to the Dashboard, Measure mode, and storage management.
5.900 - Project link sharing
Share projects more easily and identify shared spaces at a glance with these updates to link sharing and team indicators.
5.890 - More context and control in the Dashboard and modeling tools
Get clearer project context, faster sharing, and more precise control with the latest Dashboard updates and modeling tool improvements.
alt
5.880 - Navigate faster, manage items better, track edits clearly
Move around your model more precisely, find hidden parts faster, and track who edited each version with new camera controls, visibility commands, and updates to Items and Project Versions.
5.870 - Introducing Drafts and New Camera Controls
Organize your projects more intuitively with Drafts, present models from fixed angles, and fine-tune visuals and patterns with added control across tools.
5.860 - Instant Screenshots and Dynamic Section View
Speed up sharing, inspect designs more easily, and work faster with improvements to screenshots, mirroring, and Section View.
5.850 - Constraints in mirrored sketches
Model solar surfaces, capture cleaner visuals, and mirror sketches more efficiently with these latest updates.
5.840 - Tool and Section View visual updates
This release brings visual refinements to Section View and modeling tools for a clearer, more consistent modeling experience.
5.830 - More precise selections
Get more control over material settings and selections with updates to Visualization and the Selection tool.
5.820 - Enhanced selection visibility
This release brings a simple but useful update for selection.
5.810 - Fully-defined sketches
Refine your sketches with better control and visuals, plus a Webviewer update for easier sharing.
5.800 - Variables are here
Variables are here—make your models smarter and more adaptable.
5.790 - Basic expressions
Bring more precision and flexibility to your designs with expressions.
5.770 - New Visualization materials
Refine your workflow with new material finishes and improved visibility controls.
5.760 - Faster web exports
This release brings faster exports, easier imports, and a cohesive experience across platforms.
5.750 - Faster project relaunch
Keep your workflow smooth and consistent with these updates to view settings and project reloading.
5.740 - Construction Sketching
Streamline your workflow with the new Construction Sketching feature.
5.730 - Project Versions
Optimize your workflow with Project Versions, new Visualization environments, and enhanced customization options.
5.720 - Save orientation views
Discover new ways to streamline your workflow with saved orientation views, improved extrusion control, and enhanced sketch constraints.
5.710 - History sidebar updates
Check out the latest improvements to the History sidebar, along with a fix for image opacity.
5.700 - Chordal fillets
Boost your design efficiency with the latest updates to Fillets, Constraints, and USDZ exports.
5.690 - Roughness property in Visualization
Enhance your workflow with greater efficiency and precision through these new updates to Visualization, exporting, and the Extrude tool.
5.681 - Batch export option
Experience a more streamlined modeling process with these improvements to exporting options, constraints, and circular annotations.
5.660 - Invite and collaborate with Teamspace
Teamspace is finally here, along with enhancements designed to make your workflow more efficient.
5.650 - Manage references in History
Maximize your productivity with these new updates to the History and export settings.
5.640 - Quicker transformation actions
This release offers a simple yet valuable enhancement to the Move/Rotate tool.
5.630 - Create unlinked copies of bodies
Enhance your productivity with these updates to the Copy function and Extrude tool. We’ve also provided some fixes to the Project workflow and 2D Drawings.
5.620 - Merge History steps
Greatly improve your workflow with these new updates to Design History and Visualization.
5.600 - New automotive Visualization materials
This release further expands your material options in Visualization.
5.590 - History-Based Parametric Modeling is here
This release officially brings Parametric Modeling out of beta.
5.580 - New Emissive Material in Visualization
Showcase your models with this new update to Visualization. Plus, a few more enhancements to the History sidebar.
5.570 - Tidier display filters in the History sidebar
Manage longer lists more effortlessly in History with this new update to the sidebar.
5.560 - Instantly export to .shapr format
This release brings a simple but efficient update to your workflow.
5.550 - Custom-angled base views
Communicate your drawings more effectively with these new updates to 2D Drawings.
5.520 - New constraint settings
Achieve more efficiency with these new updates to constraints, project navigation, and sketches.
5.510 - Point selection workflow
Model more accurately with an improved point selection workflow.
5.500 - Update project names quickly
This release focused on remaining minor enhancements and bug fixes to give you a smoother design workflow.
5.492 - Folders are here
The wait is over: folders are finally here.
5.480 - Views in 2D Drawings
Model more effortlessly with these new updates to 2D Drawings and Section View.
5.470 - Manage your workflows more seamlessly
This release covered subtle but crucial enhancements to help improve your day-to-day workflow.
5.460 - Base and projection views
We’re back again to give you exciting updates to 2D Drawings. We also added a few more improvements to the menus.
5.450 - New Visualization materials
This release brings you exciting updates to Visualization, 2D Drawings, and the views menu section.
5.440 - User interface refresh
Introducing the Shapr3D visual refresh. Check out what’s in store for you in this user interface refresh.
5.430 - Countdown: visual refresh
This release focused on just a few bug fixes as we get ready for our upcoming big changes.
5.420 - 2D Drawings dimensions
In this release, we provided a few improvements for the 2D Drawings feature.
5.410 - Base plane selection
This release brings a small, but important improvement to the 3D modeling tool workflow.
5.400 - Manual material orientation
We have some new improvements to Visualization and 2D Drawings.
70 out of 80 found this helpful
