26.210 – Thread tool, sketch tools, import updates, and more
The Thread tool is here. Create and customize geometric threads, refine sketches with the Slot and Extend tools, and reuse existing models with 3MF import. Plus, explore new Visualization materials and interface improvements to streamline your modeling workflow.
Thread tool
Create geometric threads directly on cylindrical faces with the Thread tool, with control over the properties needed for your design.
  • Thread standard and size – Choose the thread specifications that match your requirements.
  • Pitch and tolerance – Adjust thread spacing and tolerance.
  • Direction and length – Set the thread direction and how far it extends along the cylindrical face.
Slot sketch tool
Create elongated shapes with rounded ends directly in your sketches. Choose between two construction methods to define the slot.
  • Center-to-Center – Define a slot using the centers of its rounded ends.
  • Center Point – Create a slot starting from its center point.
Extend sketch tool
Extend sketch lines and arcs to nearby geometry, helping you close gaps and connect sketch elements without redrawing them.
3MF import
Import 3MF files directly into Shapr3D to reuse existing models and streamline your 3D printing workflow. Imported 3MF files preserve their original colors, allowing you to work with multicolored designs.
Bring more detail to your designs with additional materials in Visualization, including options for different manufacturing processes, finishes, and surfaces.
  • Metals – Explore perforated metals and steel finishes.
  • 3D printing – Represent printed surfaces with PLA materials.
  • Other finishes – Choose from additional tiles, plywood, and fabrics.
Screenshot tool
The Screenshot tool now opens in a dedicated dialog, providing a more focused experience when capturing images of your designs.
Adjust the size of menu icons in Settings to suit your workspace and preferred way of interacting with Shapr3D.
  • Small – Free up modeling space and display more tools.
  • Large – Use larger icons for easier tapping.
0 out of 0 found this helpful
