Mirror frame components
82%
← Back: Extrude with Adaptive User InterfaceNext: Mirror and union bodies →
Mirror sections of your motorcycle frame using ‘Along Plane at Edge’ Construction Planes and learning how to drag your sketch onto the construction plane, then using the Sweep and Mirror tools to complete your frame.
The next thing we want to do is to create something that's out of plane. The way we're going to do this is go back to the original layout sketch and add a line that goes from the intersection of the head tube and the down tube straight back to this corner. And this line can be a normal line or construction either way.
00:25
From here we get out of the sketch and create a plane that's at an angle this time. So we'll hit Add Construction Plane, change the type to a long edge at angle, and then we follow the tips. Select an edge axis or line, so we'll select this line, hit Next. Select a face plane or filling, and we'll just use this plane. And Next.
00:54
and then it wants us to establish an angle. I want 20 degrees on this side. Okay and done. Okay so now we've got a plane that's not lined up with the world system. And now getting this sketch on the angled plane to line up with the sketch on the other plane is not exactly a straightforward thing.
01:24
So let me show you one way to do it. First, I'm going to select this region from my layout sketch, and then I'm going to drag this, and I'm going to drop it on the display of the angled plane. Now this edge that goes around gives me exactly the projection that I was looking for.
01:50
So now we can use that edge to create another sweep. So let's start by turning off body one, which is the head tube. And let's turn off some planes, the plane three that I created.
02:06
and I'm going to create another new plane that's perpendicular to this edge at that point and draw a circle. Get out of the sketch. Remember SBI.
02:22
So I'm going to click inside the circle, shift click edge, edge, edge, edge.
02:35
from that set of selections. I can only do a few things and sweep is one of them. All right, so this is swept that new tube for me. I can turn off body 3, turn body 1 back on.
02:55
And now I'll make a mirror of the new body that I just created. We'll go to tools, transform mirror items to mirror will be body four mirror plane, and we'll say, okay.
Motorcycle
Motorcycle cover
Piston
Piston rod
Rod clamp
4 motorcycle wheel
Frame
Block casting
3 out of 4 found this helpful
