Troubleshoot geometric errors
88%
← Back: Mirror and union bodiesNext: Import models →
Why do errors sometimes come up while you’re modeling? Learn why geometric errors occur and how to go about troubleshooting them with this walkthrough of shelling a motorcycle frame.
To do this shell, we'll try the SBI method, Selection Based Interface. So we'll select all the faces that we want to include in this shell. We want to remove these faces. And we'll just speed this up a little bit.
00:21
And with that selection, Shapr3D has narrowed down the types of features that I could be looking for. It knows I want a shell. And here's the arrow.
00:35
drag a thickness. Now there will be a range of thicknesses where this will work and a range where it won't work.
00:45
So let's see what happens as we drag the arrow. The operation failed because the resulting body wouldn't be valid. The arrow turns red and we get that little warning signal at the top of the screen. When the arrow is blue, it's working. Now this is not because there's any problem with the software. This failure is because just geometrically the curvature at some point inside probably has something to do.
01:13
with the intersection of these cylinders at an almost tangent. That's a rule of thumb with the shell feature is that small shell values generally work out better than large shell values. One reason you would want to have a model with an actual shell is to get a good weight approximation. And you do a weight approximation by measuring the volume of the entire body.
01:42
that case this is body four. So you've got almost 29 cubic inches of steel in the frame without the plate and you would need to multiply that by the density of steel to get your actual weight for the frame. There are other methods for modeling bent steel frames. Sweeping is just one of them. You could extrude, you could revolve, you could even loft.
02:06
depending on the needs in your particular situation. All CAD programs involve some workarounds now and then, and Shapr3D is not immune. So some of the methods I used here were a little unorthodox, but you have to be creative and understand how your tools work. Thanks for watching this set of videos. I hope you found them interesting and informative.
Motorcycle
Motorcycle cover
Piston
Piston rod
Rod clamp
4 motorcycle wheel
Frame
Block casting
4 out of 9 found this helpful
