Experience a more streamlined modeling process with these improvements to exporting options, constraints, and circular annotations:
Batch export option
Export your projects in multiple formats faster and more efficiently with the new batch export option.
To use the batch export, Export as how you normally would and then click the new Select option at the top of the Export screen. Select the formats you need and update any necessary project details. To finish, select Export to save the files to your device.
Angle constraints
Now you can create angle constraints between a body edge and a sketch.
After creating a constraint between a sketch and a body edge, you can easily adjust the angle by selecting the angle annotation while in sketch mode. From there, you can modify the angle value and reposition the annotation as needed.
Circular annotations
Circular annotations now stay where you place them, preventing them from jumping to a default location as shown in the illustrations below.
Before:
After:
