5.690 - Roughness property in Visualization
Enhance your workflow with greater efficiency and precision through these new updates to Visualization, exporting, and the Extrude tool:
Fine-tune your material appearances with the new Roughness property in Visualization. Several materials now also have sharper detail and more defined textures, providing enhanced visual clarity in your models.
To use the Roughness property, just go to the Material settings and adjust the material roughness using the slider.
Favorite file formats during export
Now you can favorite your most-used file formats during export for quick and easy access.
To favorite a format, hover over a file format and then select the star symbol.
Batch export from the Dashboard
Select and batch export multiple files from the Dashboard in your favorite file formats.
From the Dashboard, right-click (secondary click) on the project you want to export and then select Export to Favorite formats.
Export tool remembers last used settings
Export your projects much more efficiently with the Export tool now remembering your last used export settings.
In the example below, the selected settings for each file format will be preserved when creating another export.
Symmetric extrude in Extrude tool
The Extrude tool now supports symmetric extrude.
To create a symmetric extrude, simply navigate to the Extrude step and select the Symmetric option from the Sides drop-down menu.
0 out of 1 found this helpful
