Streamline your workflow with the new Construction Sketching feature:
Construction Sketching toggle
Now you can toggle Construction Sketching in sketch mode, allowing you to use all sketch tools and the Offset tool for construction sketches. This session-based toggle resets automatically when you exit sketch mode to keep your workflow uninterrupted.
To enable Construction Sketching, simply turn on Construction located in the modes area. Once activated, all sketches you create will automatically be set as construction sketches until you exit sketch mode.
