5.920 - Access sharing during export
Work more efficiently with updates to sharing, the Offset Edge tool, and design history navigation:
Access Project and Review Link sharing from the Export modal
Now you can access Project and Review Link sharing from the Export modal for easy access while exporting.
Quickly share your project without exporting or manually sending files. You can also create a Review Link instead of exporting to PDF, DXF, or DWG, giving stakeholders an interactive way to view your model in AR directly from their browser.
Offset Edge now creates offset constraints
The Offset Edge tool now creates offset constraints to keep new offsets linked to their original geometry for predictable edits. You can also use variables and expressions with offset constraints to build parametric sketches that update automatically.
Offset Edge now supports Single and Chain types
The Offset Edge tool now uses Single and Chain types. The previous Loop type is now Chain, which supports closed loops, and connected edges and sketches for more flexible offsets.
Smoother Design History scrolling
Navigating through your Design History is now more responsive and fluid, making it easier to review earlier steps or jump back to a specific edit. This improvement is especially helpful when working with long, complex histories where you need to fine-tune or revise earlier operations.
3 out of 3 found this helpful
