5.970 - Advanced Split Options
Split bodies more efficiently, share projects without teams, and fine-tune your workspace setup. This update brings new flexibility to modeling, collaboration, and navigation.
Split Body supports multiple tools
The Split Body tool now accepts multiple splitting tools in a single History step. You can divide a body using several faces or sketch curves at once, with adjacent faces and coplanar edges merging automatically into a single profile. This speeds up complex modeling workflows and helps maintain cleaner history steps when working with multi-surface geometry.
To learn more, visit Split Body.
Shared projects for individual collaborators
Projects can now be shared directly with individual collaborators without adding them to a team. Invite by email to grant edit access or share a link so others can view or request access. Shared projects appear in the Shared with Me section of the Dashboard, making it easier to manage collaboration without reorganizing your workspace.
Drafts for early-stage work
The Drafts section now focuses on early-stage or shared projects that aren’t yet part of a Space. Use it to keep exploratory or in-progress work separate from finalized designs, keeping your Dashboard organized and helping you track design progress more clearly.
The Navigation Presets list has been expanded with new options for Alias, CATIA, and NX. You can now match camera controls to the CAD system you’re most familiar with, making it easier to adapt Shapr3D to your existing workflow.
4 out of 5 found this helpful
