Sketch menu: Rotate Around Axis
Learn how to rotate sketch items around a selected axis in Shapr3D.
What is the Rotate Around Axis tool?
You can use the Rotate Around Axis icon-transform-rotate-around-axis.png tool to rotate sketch items around a selected line, edge, or axis. Set a rotation angle and optionally create a rotated copy while keeping the original sketch items unchanged.
To learn how to rotate 3D geometry, visit Transform menu: Rotate Around Axis tool.
How to use the Rotate Around Axis tool
  1. Go to Sketch > Rotate Around Axis.
  2. Select the sketch items you want to rotate.
  3. Select Next, if prompted, to proceed to axis selection.
  4. Select a line, edge, or axis to rotate around.
  5. Optional: Select the Copy badge to rotate a duplicate instead of the original selection.
  6. Drag the rotation control to set the angle, or select the angle label to enter a precise value.
  7. To finish, select an empty area of the modeling space.
Turn on Copy to create a rotated duplicate while keeping the original selection unchanged.
Rotating sketch items around an axis does not create a separate Rotate Around Axis step in History. You can still reopen the existing Sketch step to review or modify its settings:
When to use the Rotate Around Axis tool
Use Rotate Around Axis to:
  • Reposition sketch geometry – Rotate selected sketch items around a defined reference axis.
  • Create repeated angled geometry – Use Copy to preserve the original and place a rotated duplicate.
  • Adjust angled profiles – Set a precise rotation angle for sketch items relative to a chosen axis.
  • Select the intended axis before setting the rotation angle.
  • Use the angle label when you need an exact value.
Issue What to check
The sketch items rotate around the wrong axis. Check the selected line, edge, or axis and choose the intended reference.
The original sketch items were rotated instead of duplicated. Turn on Copy before applying the rotation.
The rotation angle is incorrect. Select the angle label and enter the intended value.
0 out of 0 found this helpful
