5.660 - Invite and collaborate with Teamspace
Teamspace is finally here, along with enhancements designed to make your workflow more efficient:
Now you can invite members and collaborate using the new Teamspace in the Dashboard.
Simply click Invite Members... to start inviting your team members and store your projects under Teamspace to automatically share them with your team.
To learn more, visit the following pages:
History sidebar warning symbol
The History sidebar button now alerts you with an error warning symbol, notifying you of Design History errors even when the sidebar is closed.
Adaptive menu now adapts to screen height
The adaptive menu now adapts to screen height, only using the ‘More’ menu if all options can’t fit within the window.
Geometry and texture compression for GLB exports
Now you can turn off geometry and texture compression for GLB exports, enhancing compatibility with other applications.
The Trim tool now stays active
The Trim tool now stays active until you exit sketching or press Escape, allowing you to continue trimming sketches even when clicking or tapping away.
0 out of 2 found this helpful
