Working with NX and Shapr3D
NX is a powerful CAD/CAM/CAE software suite developed by Siemens that offers robust tools for 3D modeling and simulation, widely used across industries for product design, engineering, and manufacturing. Use NX with Shapr3D to take advantage of Shapr3D’s intuitive and portable features while keeping the robust capabilities of NX.
Why use NX with Shapr3D?
  • Enhanced collaboration: Work across devices integrating Shapr3D and NX seamlessly—no file conversion needed. Concept and review in Shapr3D and then pick back up in NX in your office to finalize your design.
  • Simplified workflows: Create multiple diverse iterations in a fraction of the time; then seamlessly import to NX for refinement.
How to use NX with Shapr3D
Step 1: Export from NX
    1. Open your model in NX.
    2. Export parts to supported file formats such as NX’s default format .prt, .x_t, or choose other file formats compatible with Shapr3D.
Important
Features recorded in NX will not carry over when imported into Shapr3D.
Step 2: Import into Shapr3D
    1. Open Shapr3D.
Important
New design history and steps recorded in Shapr3D will not carry over when you import your project back into NX.
Step 4: Export from Shapr3D
    2. You can save parts as .x_t and .step files, or choose other file formats compatible with Shapr3D.
Step 5: Import back to NX
    1. Open NX.
    2. Import your model back into NX.
9 out of 14 found this helpful
