Working with OnShape and Shapr3D
OnShape is a cloud-based CAD software that offers powerful tools for 3D modeling, collaboration, and data management, allowing you to work on your designs from anywhere with an internet connection. Use OnShape with Shapr3D to combine the cloud capabilities of OnShape with the intuitive modeling features of Shapr3D.
Why use OnShape with Shapr3D?
  • Enhanced collaboration: Work across devices integrating Shapr3D and OnShape seamlessly—no file conversion needed. Concept and review in Shapr3D and then pick back up in OnShape in your office to finalize your design.
  • Simplified workflows: Create multiple diverse iterations in a fraction of the time; then seamlessly import to OnShape for refinement.
How to use OnShape with Shapr3D
Step 1: Export from OnShape
    1. Open your model in OnShape.
    2. Export parts to supported file formats such as .x_t, .step or choose other file formats compatible with Shapr3D.
Important
Features, steps, or design history recorded in OnShape will not carry over when imported into Shapr3D.
Step 2: Import into Shapr3D
    1. Open Shapr3D.
Important
New design history and steps recorded in Shapr3D will not carry over when you import your project back into OnShape.
Step 4: Export from Shapr3D
    2. You can save parts as .x_t and .step files, or choose other file formats compatible with Shapr3D.
Step 5: Import back to OnShape
    1. Open OnShape.
    2. Import your model back into OnShape.
1 out of 2 found this helpful
