Working with Fusion 360 and Shapr3D
Fusion 360, developed by Autodesk, is a cloud-based CAD software that provides powerful tools for 3D modeling, simulation, and manufacturing, widely used for its collaborative features and comprehensive design capabilities. Use Fusion 360 with Shapr3D to combine the advanced features of Fusion 360 with Shapr3D’s intuitive interface and portability.
Why use Fusion 360 with Shapr3D?
  • Enhanced collaboration: Work across devices integrating Shapr3D and Fusion 360 seamlessly—no file conversion needed. Concept and review in Shapr3D and then pick back up in Fusion 360 in your office to finalize your design.
  • Simplified workflows: Create multiple diverse iterations in a fraction of the time; then seamlessly import to Fusion 360 for refinement.
How to use Fusion 360 with Shapr3D
Step 1: Export from Fusion 360
    1. Open your model in Fusion 360.
    2. Export parts to supported file formats such as .x_t, .step, or choose other file formats compatible with Shapr3D.
Important
Features, steps, or design history recorded in Fusion 360 will not carry over when imported into Shapr3D.
Step 2: Import into Shapr3D
    1. Open Shapr3D.
Important
New design history and steps recorded in Shapr3D will not carry over when you import your project back into Fusion 360.
Step 4: Export from Shapr3D
    2. You can save parts as .x_t and .step files, or choose other file formats compatible with Shapr3D.
Step 5: Import back to Fusion 360
    1. Open Fusion 360.
    2. Import your model back into Fusion 360.
9 out of 12 found this helpful
