Working with Creo and Shapr3D
Creo, developed by PTC, is a powerful CAD software that offers robust tools for 3D modeling and engineering widely used for product design, simulation, and manufacturing. Use Creo with Shapr3D to leverage Shapr3D’s intuitive interface and portability while maintaining the advanced capabilities of Creo.
Why use Creo with Shapr3D?
  • Enhanced collaboration: Work across devices integrating Shapr3D and Creo seamlessly—no file conversion needed. Concept and review in Shapr3D and then pick back up in Creo in your office to finalize your design.
  • Simplified workflows: Create multiple diverse iterations in a fraction of the time; then seamlessly import to Creo for refinement.
How to use Creo with Shapr3D
Step 1: Export from Creo
    1. Open your model in Creo.
    2. Export parts to supported file formats such as .x_t, .step or choose other file formats compatible with Shapr3D.
Important
Features, steps, or design history recorded in Creo will not carry over when imported into Shapr3D.
Step 2: Import into Shapr3D
    1. Open Shapr3D.
Important
New design history and steps recorded in Shapr3D will not carry over when you import your project back into Creo.
Step 4: Export from Shapr3D
    2. You can save parts as .x_t and .step files, or choose other file formats compatible with Shapr3D.
Step 5: Import back to Creo
    1. Open Creo.
    2. Import your model back into Creo.
6 out of 7 found this helpful
