Working with SolidWorks and Shapr3D
SolidWorks, developed by Dassault Systèmes, is a popular CAD software used for 3D modeling, simulation, and product design widely used in engineering and design fields. Use SolidWorks with Shapr3D to utilize the strengths of both platforms for a more efficient workflow.
Why use SolidWorks with Shapr3D?
  • Enhanced collaboration: Work across devices integrating Shapr3D and SolidWorks seamlessly—no file conversion needed. Concept and review in Shapr3D and then pick back up in SolidWorks in your office to finalize your design.
  • Simplified workflows: Create multiple diverse iterations in a fraction of the time; then seamlessly import to SolidWorks for refinement.
How to use SolidWorks with Shapr3D
Step 1: Export from SolidWorks
    1. Open your model in SolidWorks.
    2. Export parts to supported file formats such as SolidWorks’s default format .sldprt, .sldasm or choose other file formats compatible with Shapr3D.
Important
Features, steps, or design history recorded in SolidWorks will not carry over when imported into Shapr3D.
Step 2: Import into Shapr3D
    1. Open Shapr3D.
Important
New design history and steps recorded in Shapr3D will not carry over when you import your project back into SolidWorks.
Step 4: Export from Shapr3D
    2. You can save parts as .x_t and .step files, or choose other file formats compatible with Shapr3D.
Step 5: Import back to SolidWorks
    1. Open SolidWorks.
    2. Import your model back into SolidWorks.
12 out of 14 found this helpful
