Working with CATIA and Shapr3D
CATIA, developed by Dassault Systèmes, is a leading CAD software that offers advanced capabilities for 3D modeling, simulation, and product lifecycle management, widely used for product design and engineering in various industries. Use CATIA with Shapr3D to combine CATIA’s robust features with Shapr3D’s user-friendly interface and portability.
Why use CATIA with Shapr3D?
  • Enhanced collaboration: Work across devices integrating Shapr3D and CATIA seamlessly—no file conversion needed. Concept and review in Shapr3D and then pick back up in CATIA in your office to finalize your design.
  • Simplified workflows: Create multiple diverse iterations in a fraction of the time; then seamlessly import to CATIA for refinement.
How to use CATIA with Shapr3D
Step 1: Export from CATIA
    1. Open your model in CATIA.
    2. Export parts to supported file formats such as CATIA’s default format .catpart, .catproduct, or choose other file formats compatible with Shapr3D.
Important
Features, steps, or design history recorded in CATIA will not carry over when imported into Shapr3D.
Step 2: Import into Shapr3D
    1. Open Shapr3D.
Important
New design history and steps recorded in Shapr3D will not carry over when you import your project back into CATIA.
Step 4: Export from Shapr3D
    2. You can save parts as .x_t and .step files, or choose other file formats compatible with Shapr3D.
Step 5: Import back to CATIA
    1. Open CATIA.
    2. Import your model back into CATIA.
10 out of 15 found this helpful
