Working with Alias and Shapr3D
Alias, developed by Autodesk, is a leading CAD software that offers powerful tools for 3D surface modeling and visualization for industrial design, automotive design, and styling. Use Alias with Shapr3D to take advantage of Shapr3D’s intuitive interface and portability while working on detailed design projects.
Why use Alias with Shapr3D?
  • Enhanced collaboration: Work across devices integrating Shapr3D and Alias seamlessly—no file conversion needed. Concept and review in Shapr3D and then pick back up in Alias in your office to finalize your design.
  • Simplified workflows: Create multiple diverse iterations in a fraction of the time; then seamlessly import to Alias for refinement.
How to use Alias with Shapr3D
Step 1: Export from Alias
    1. Open your model in Alias.
    2. Export parts to supported file formats such as .x_t, .step or choose other file formats compatible with Shapr3D.
Important
Features, steps, or design history recorded in Alias will not carry over when imported into Shapr3D.
Step 2: Import into Shapr3D
    1. Open Shapr3D.
Important
New design history and steps recorded in Shapr3D will not carry over when you import your project back into Alias.
Step 4: Export from Shapr3D
    2. You can save parts as .x_t and .step files, or choose other file formats compatible with Shapr3D.
Step 5: Import back to Alias
    1. Open Alias.
    2. Import your model back into Alias.
6 out of 6 found this helpful
