5.730 - Project Versions
Optimize your workflow with Project Versions, new Visualization environments, and enhanced customization options:
Project Versions
Now you can track and restore previous versions of your projects with Project Versions, ensuring your work is safeguarded and revisions are easy to manage from the Dashboard.
To access a previous version, right-click on a project in your Dashboard, select Show Versions, and then choose the version you want to restore.
To learn more, visit Project Versions.
New Visualization environments
Enhance the quality of your renders with two detailed environments added to Visualization for greater variety and control over lighting and scene settings.
Simply try out the new Bright Exhibition Space and Dark Exhibition Space environments to see how they enhance your models with realistic lighting and shadows.
Camera animation toggle
Instantly toggle Camera animations in the View menu to switch between smooth transitions or immediate changes when navigating different views and angles, adapting to your workflow and preferences.
To adjust the animation setting, go to the View menu and toggle Camera Animation to your preferred mode.
Customize keyboard shortcuts
Now you can customize keyboard shortcuts to boost your workflow efficiency.
Go to Settings and select Keyboard Shortcuts to set up custom shortcuts for your frequently used tools and commands.
To learn more, visit Keyboard shortcuts, gestures, and hotkeys.
Clearer visual indicators for mode states
Mode states like Isolate, Section View, and Measure now have clearer visual indicators, allowing you to identify active modes much more quickly.
The active mode states are now visually distinct, making it easy to see which modes are engaged.
0 out of 1 found this helpful
