Line
Use the Line icon-sketch-line.png tool under the Sketch menu to create lines and adjust their dimensions. With lines, you can construct custom shapes that you can use for your model.
Create a line
By default, you can create connecting lines through a series of endpoints. Follow these steps to learn how:
  1. Define your sketch plane.
  2. Select Sketch > Line.
  3. To draw a line, click to add an endpoint.
  4. Drag your pointer to construct your line.
  5. Click to add another endpoint.
  6. To draw connecting lines, continue to click and drag your pointer to add more endpoints.
  7. To finish drawing lines you can do either of the following:
    • Press Escape to cancel or exit an active endpoint.
    • Press Enter to set your final endpoint.
Note: Your drawing will automatically finish if you draw a closed shape by connecting the last endpoint to your initial endpoint.
To manage history settings for the automatic Line action, find the step for your specific sketch and then view or modify the following:
Video walkthrough
24 out of 36 found this helpful
