Circle
The Circle icon-sketch-circle.png tool creates a closed sketch profile with a constant radius.
Create a circle
To create a circle:
  1. Define your sketch plane, go to Sketch > Circle.
  2. Click to place the center of the circle, then click to place the diameter of the circle.
    Note: You can specify the value for the circle annotation by entering it on the keyboard before placing the diameter.
When drawing the circle or selecting an existing circle, you will see either a radius or diameter dimension label, depending on your Circular Annotations setting in Settings or Preferences
To manage history settings for the automatic Circle action, find the step for your specific sketch and then view or modify the following:
Video walkthrough
9 out of 28 found this helpful
