Rectangle
Use the Rectangle icon-sketch-rectangle-center.png tool under the Sketch menu to create rectangles and adjust their dimensions.
Create a rectangle
To select the type of rectangle you want to create, follow these steps:
  1. Define your sketch plane, go to Sketch > Rectangle.
  2. Select the menu below Rectangle to access the Rectangle type options.
    • Center rectangle – A center rectangle is defined by its center point. When you select somewhere on the grid, that point becomes the center of the rectangle (and an anchor point, which is indicated by the X-mark) and you can drag the shape to create the sides of the rectangle.
    • Diagonal rectangle – A diagonal rectangle is defined by its two opposite corners. When you select somewhere on the grid, you need to drag an imaginary diagonal line. This line becomes the diagonal length of the rectangle, and the initial point becomes the anchor point.
    • Three-point rectangle – A three-point rectangle is defined by three points by first drawing a baseline, and then drawing the height. The remaining sides of the rectangle are automatically created based on the two sides, or three points you specified. The first point you create becomes the anchor point.
  3. Select the type of rectangle you want to create.
To create a Center Rectangle:
  1. Click to place the center of the rectangle
  2. Drag your cursor and click to place an outer vertex for the rectangle.
To create a Diagonal Rectangle :
  1. Click to place the starting diagonal point of the rectangle.
  2. Drag your cursor diagonally and click to place an outer vertex for the rectangle.
To create a Three-Point Rectangle:
  1. Click to place the starting point of the rectangle, then move your pointer to draw a line. This will be the length of your baseline. Click to finalize the length of the baseline.
  2. Move your pointer perpendicular to the baseline to define the shape of the rectangle. Click to finalize the shape of the rectangle
To manage history settings for the automatic Rectangle action, find the step for your specific sketch and then view or modify the following:
Video walkthrough
13 out of 23 found this helpful
