Polygon
The Polygon icon-sketch-polygon-pentagon.png tool creates a closed sketch profile with a specified number of equal sides. There are several pre-defined polygon types available. Once a polygon is created, you can customize the number of sides if necessary.
Create a polygon
To create a Polygon:
  1. Define your sketch plane, go to Sketch > Polygon.
  2. Select the menu below Polygon to access the Polygon type options.
  3. Select the type of polygon you want to create. The types of pre-defined polygons include:
    • Triangle
    • Pentagon
    • Hexagon
    • Octagon
      Note: You can adjust the number of sides for the polygon after you place it in the sketch.
  4. Click to place the center of the polygon, then move your pointer to define the radius. Click to place the outer vertex.
    Note: You can specify the radius for the polygon before placing the vertex by typing the value.
  5. Use the dimension labels to adjust the number of polygon sides and define the radius.
    Note: The label for adjusting the number of sides will only be available immediately after creating the polygon. If you need to adjust this parameter, select the sides label first. Once another selection is made, the sides label will disappear.
To manage history settings for the automatic Polygon action, find the step for your specific sketch and then view or modify the following:
Video walkthrough
6 out of 12 found this helpful
