Offset Edge (Sketch)
The Offset Edge icon-sketch-offset-edge-loop.png tool creates new sketch elements that are offset from existing elements by a specified distance. You can use the Offset Edge tool within a sketch, with sketch profiles, or with the edges and faces of a 3D body.
Note: For information on using Offset Edge with sketch profiles and edges of 3D bodies, visit Offset Edge (3D).
Offset sketch edges
To offset from a sketch element:
  1. Within an existing sketch, go to Sketch > Offset Edge.
  2. Select Type to access the Offset Edge Type menu.
  3. Choose an offset type:
    • Single – Offsets a single edge from a sketch element.
    • Chain – Offsets a chain of edges from a sketch element.
  4. Select the sketch element you want to offset.
  5. Use the gizmo to specify the offset direction and distance using one of these methods:
    Note: If you select a sketch item that is shared by multiple loops, arrows will be displayed for each loop. Select the appropriate arrow for the loop you want to offset.
  6. To finish, select Exit Sketching.
To manage history settings for the automatic Offset Edge action, find the step for your specific sketch and then view or modify the following:
Video walkthrough
10 out of 18 found this helpful
