Coincident
When geometric elements are coincident, it means they are overlapping. You can use the Coincident icon-constraint-coincident.png constraint to make sketch endpoints coincident with other elements to make them connected.
How to create a coincident constraint
To create a Coincident constraint:
  1. On the same sketch plane, select an endpoint and another element.
  2. Select Coincident from the constraints menu or drag an endpoint onto the element you want to connect to.
    Note: Endpoints can be made Coincident to other endpoints, lines, curves, and edges.
Video walkthrough
Endpoints that are connected to elements with a Coincident constraint are shown with a filled center. For more information, visit States of sketch points.
6 out of 7 found this helpful
