Constraint Settings
The Constraint Settings icon-generic-settings-win.png option is where you can adjust options related to constraints. You can find this option in the constraints menu opposite the sketch menu whenever you're working in sketch mode.
Auto-constraining
The Auto-constraining option can be adjusted to control if constraints are added to your sketch automatically or manually.
When turned off, the only constraints that are automatically created are between connected endpoints or midpoints. To create additional constraints, select sketch elements and choose your preferred constraint from the constraints menu.
When turned on, as you create sketch elements, constraints for connected endpoints and midpoints are automatically created including Horizontal/Vertical, Perpendicular, Tangent (when an arc is created at an endpoint), and Coincident.
Use Sketch Guide Lines to align geometry and automate these constraints. For more information on Sketch Guide Lines, visit Snapping Options.
Constraint & Locked Dimension Visibility
The Constraint & Locked Dimension Visibility setting controls how constraint icons for the active sketch are shown.
  • Always Show Constraints – When turned on, constraint icons are only shown for selected sketch elements.
  • Always Show Dimensions – When turned on, all locked dimensions for the active sketch are shown in the modeling space.
Anchored Sketch Entity
The Anchored Sketch Entity setting allows you to specify whether the first or last selected sketch entity stays in place when applying constraints, making it easier to control which part of your sketch moves or stays fixed.
  • First Selected – When you choose this option, all sketch entities will be moved relative to the one you selected first.
  • Last Selected – When you choose this option, all sketch entities will be moved relative to the one your selected last.
Note: Existing constraints override this setting.
Video walkthrough
12 out of 38 found this helpful
