Constraints: Horizontal/Vertical
Learn how to use the Horizontal/Vertical constraint to align sketch lines and points horizontally or vertically relative to the sketch plane.
What is the Horizontal/Vertical constraint?
You can use the Horizontal/Vertical icon-constraint-horizontal-vertical.png constraint to align sketch lines or points horizontally or vertically. Horizontal and vertical directions in a sketch correspond to the axes of the sketch plane.
The Horizontal/Vertical constraint supports the following sketch geometry:
  • Lines – Constrain one or more sketch lines to a horizontal or vertical direction.
  • Points – Align two sketch points horizontally or vertically without creating a connecting line.
How to create a Horizontal/Vertical constraint
Constrain sketch lines
To make sketch lines horizontal or vertical:
  1. Select one or more lines on the same sketch plane.
  2. From the Constraints menu, select Horizontal/Vertical.
The selected lines align with the axis closest to their original direction.
Constrain sketch points
To align two sketch points horizontally or vertically:
  1. Select two points on the same sketch plane.
The constraint establishes a horizontal or vertical relationship between the selected points without requiring a line connecting them.
When to use the Horizontal/Vertical constraint
The Horizontal/Vertical constraint is useful for:
  • Creating orthogonal profiles – Keep sketch lines horizontal or vertical when creating rectangular or other orthogonal shapes.
  • Aligning separate sketch items – Align points belonging to different sketch items without adding connecting geometry.
  • Positioning circular features – Align the center points of circles or arcs along a horizontal or vertical direction.
  • Maintaining sketch relationships – Preserve horizontal or vertical alignment when modifying sketch dimensions or geometry.
  • Use the Horizontal/Vertical constraint on lines when you want to control their orientation.
  • Apply the constraint directly to points when you want to align sketch items without creating additional geometry.
  • Remember that horizontal and vertical directions are relative to the sketch plane.
  • Review existing constraints if the selected geometry cannot be aligned.
Issue What to check
The constraint is unavailable. Check that you have selected supported sketch geometry on the same sketch plane.
A line aligns in the wrong direction. The alignment is based on the line's original direction. Undo the action, adjust the line closer to the intended direction, and apply the constraint again.
The selected geometry cannot be aligned. Check for existing dimensions or constraints that conflict with the intended alignment.
You can automatically create Horizontal/Vertical constraints while sketching when Auto-constraining is turned on. To learn more, visit Constraint Settings.
3 out of 4 found this helpful
