You can use the Horizontal/Vertical constraint to create a horizontal or vertical relationship between linear sketch elements. Horizontal and vertical directions in a sketch are aligned with the axes of the sketch plane.
How to create a horizontal/vertical constraint
To create a Horizontal/Vertical constraint:
- Select a single or multiple lines on the same sketch plane.
- From the constraints menu, select Horizontal/Vertical.
Note: The line(s) are aligned with the axis closest to their original direction.
Video walkthrough
You can automatically create Horizontal/Vertical constraints while sketching when the constraint setting for Auto-constraining is turned on. For more information, visit Constraint Settings.
