Disconnect
Updated May 14, 2026 10:03
The Disconnect constraint is used to break the connection between connected points.
How to use a disconnect constraint To use Disconnect:
Select a connected line, arc, endpoint, or center point on the same sketch plane.
From the constraints menu, select Disconnect or directly select for sketch points. Note : Disconnect will delete any Coincident or Midpoint constraints for a selected point.
Video walkthrough
Connected sketch points are shown with a filled center. For more information, visit States of sketch points .
Yes
No
1 out of 5 found this helpful
#FFD480
Sketching
#505050
custom
3D modeling
#FDB08A
custom
Documentation
#C194FF
custom
Visualization
Custom block text
#9ECBAB
custom
Import & export
Custom block text
#C6EFFE
custom
EDU license
Custom block text
