Lock/Unlock
Updated
The Lock/Unlock
constraint fixes a selected sketch element in its current position and the Unlock constraint removes any locked constraint.
How to create a lock constraint
To use the Lock or Unlock constraint:
Select an endpoint or center point in the sketch.
- From the constraints menu, select Lock
or Unlock
Note: You can also directly select
or
on sketch points.
Video walkthrough
Locked sketch points are shown as a solid blue color. For more information, visit States of sketch points.
#FFD480
Sketching
#505050
custom
3D modeling
#FDB08A
custom
Documentation
#C194FF
custom
Visualization
Custom block text
#9ECBAB
custom
Import & export
Custom block text
#C6EFFE
custom
EDU license
Custom block text
